Question about Garden
Have a craftsman model :917.273621, with a briggs & stratton 24 hpohv...familyy;ybsxs.7242vf. will cut good for 30 minutes, then sputter and stall. I disengage blades, and pull out choke to keep it running. repair shop cleaned carb, new plugs, new fuel pump, but still stalls after cutting grass for 30 minutes !!drained fuel tank and blew out lines, but same problem. The repair shop is stumped... Troy
  • 84 Answers
Try the coil. the coil will produce the spark for the spark plug seeing as there is no battery, try replacing it with another of the same power.
Posted on Jun 24, 2009
I need to find free diagram for linkage hookup on a 10 HP Briggs & Stratton Snapper riding lawnmower
I would go to mytractorforum.com, click on the word 'forum' just to the right of the tractor wheel, and scroll down to the small engines and repair section. Inside 'stickies' is a directory of B&S service manuals.
Apr 14, 2013 | Snapper Garden
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
What type of oil do I use for Craftsman 42" Briggs & Stratton 17.5 hp Gas Powered Riding Lawn Tractor for oil change
Only use SAE 30 if using conventional oil. Briggs is real specific about that. I highly recommend using synthetic oil in ALL lawn equipment. You can use a multi-viscosity oil like SAE 10W-30 if you use synthetic, but straight 30 weight if using conventional. The brand is up to you.
Jun 08, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
23hp briggs won't run when it's hot.
probably ignition coil.common problem
Jun 29, 2010 | Briggs & Stratton Garden
New Craftsman 20hp Briggs & Stratton 42" riding mower, Model 917.289104. Loses power, dies while mowing. Will not start unless sits 20-30 minutes. Problem began second time I owed with it. ...
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
Jan 23, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
You first need to locate the model number on the mower, not the Briggs engine. Then go to searspartsdirect.com and enter your model number on the right side of the web page. This will take you to a list of parts for your mower. Your model number should be located on the deck of the mower (you didn't say if it was a rider or a push). Rider model numbers are located on the rear of the body behind, on or under the seat. Push model numbers are found on the back of the deck between where the handles attach to the frame.
May 25, 2009 | Craftsman Garden
Garden Logo
468 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
