Question about Motorola Baby Gear
How to pair - Motorola Baby Gear
  • Official Brand Answer
  • 3,100 Answers
Visit Looking For Help
Mark
Motorola Support
Posted on Jan 10, 2015
I want to reset my HBS 900 to my phone I have a ZTE from cricket how will I be able to do that
Your manual is here. You just need to go into the Cricket settings and go to Bluetooth and Pair. You don't have to reset the headset.
ENG
1) Easy Pairing a) Slide the Power switch to the ON position. b) If it is your first time pairing the device it will automatically enter pairing mode. If it has been paired but no paired device is in range it will enter pairing mode after 10 seconds. • The LED indicator will be solid blue. c) On the device you wish to pair, find the Bluetooth menu and search for or add new devices. d) Select LG HBS900 from the list of devices. e) If asked for a Pass/Pin Code enter 0000 (4 Zeros). f) Once the devices are paired, you will hear “Your headset paired.” • The HBS-900 will automatically turn off if not paired within 3 minutes. 2) Manual Pairing (pairing with another phone or re-pairing) a) With the power off, press the CALL button and slide the Power switch to the ON position at the same time for 2 seconds. b) When the headset enters Pairing Mode, the LED indicator will show a solid blue light. After the procedure repeat Easy Pairing steps c though f.
http://www.lg.com/us/support-product/lg-HBS-900#manuals
Sep 23, 2016 | ZTE Cell Phones
Sm-g31or5 want to pair with my 07 toyota solara convertible. phone says paired, but not car
Just had to pair for a friend few days ago, Toyou press setupota will pair to audio, but not hands free talk. Not sure exactly what buttons to push on your particular, so I would suggest read your car manual for "Hands Free Bluetooth" Pairing, not just audio pairing. On Toyota that I paired, after you press setup Bluetooth you will have to press "Phone Off" button on your steering wheel to get into hands free pairing, but check your manual to be sure.
Apr 09, 2015 | Samsung Cell Phones
How do i put lg hbs-700 into pairing mode
I had the same issue, fixed by using the Manual mode for pairing. From the manual:
2) Manual Pairing (Pairing with another phone or re-pairing)
a) With the Power off, press the CALL button and move the power switch to the
'ON' position at the same time for 4 seconds.
blue light. After the procedure repeat Easy Pairing steps c through f.
Steps C through F are to go to the bluetooth settings area and manually select the HBS-700 for pairing.
Mar 14, 2015 | Home
Power Pair
It doesn't have one. The voice pair (3+4 or 4+5 on an 8-pin jack) has 24 volts DC and the data pair less, but the power to run the phone comes from both pairs, or more probably from the voice pair.
Carl
Apr 28, 2012 | AT&T Lucent MLS-12D Phone
Describe your pairing code for nokia ck 7w Problem i just need the pairing code
There is no default pairing code for the phone. You have to enter any pairing code and then enter the same pairing code in other device.
However, if you are trying to pair Bluetooth headset, check the headset manual to find its default pairing code.
May 24, 2011 | Cell Phones
How can I put use it on my samsung phohe
Hi, Problem solved. All you need to do is to know how to pair the headset with your phone. Ones you pair the phone to your headset,your done..
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps...
Oct 29, 2010 | Mizco Radio Communications
I need pass key for Jabra BT530 to pair with cell phone.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 06, 2010 | Cell Phones
How to put a hbh705 into pairing mode
Take care.
Aug 06, 2010 | Sony Bluetooth Headst HBH705 Sandcolor...
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
Baby Gear Logo
102 people viewed this question
Top Motorola Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Motorola Baby Gear Expert? Answer questions, earn points and help others
