Question about Iomega Prestige 1 TB USB 20 Hard Drive
Iomega hard drive power won't stay on
Iomega hard drive will not stay powered on. Starts with lights working, can hear things working inside, but lights go out and all quiet after few minutes. Computer won't recognize it at all.
  • 9 Answers
SOURCE: Iomega 250 GB external stopped working
This is really not a solution, but you should all try to connect your iomega to a imac, and use the Disk Utility (in Utilities folder), if you have any luck the hard drive will be recognized and you will be able to format it
Posted on Feb 14, 2009
Crankstart
  • 696 Answers
SOURCE: My computer doesn't recognize my external hard drive
Hi Trajan & Cossrock,
Both may be as simple as stopping in at the local computer store and buying a new enclosure to move the drive into, however in Trajans case if the drives were working as a stripe set yours will likely need more in depth help.
So Cossrock, pop into your local computer store and have them test the AC adapter, it may simply need replacing, if not then try moving the drive to a new enclosure. If that doesn't work then you will need the help of a Data Recovery Expert and I can point you in the right direction, just comment back here and let me know how you made out.
Trajan, if your NAS box was simply running two drives seperately you should be able to move them into seperate cases or another dual drive case similar to Cossrocks solution, however if they are RAIDed you will likely need more assistance, please check and comment back if they are in RAID format. Also even if they are not in RAID many NAS boxes use a Linux OS and therefor a Linux format on the drive, if this is the case comment back and I will get you a link to a Linux file format driver but please include your OS Wndows Vista/XP/2000, Mac, Linux etc.
Well folks hope this helps you both out and like I said comment back with an update if you run into trouble and I will keep helping on the next steps.
Chris
Posted on May 20, 2009
lifebyguitar
  • 57 Answers
SOURCE: iomega external not visible
Unfortunately, Windows isn't the most efficient operating system when it comes to it's "Plug 'n Play" abilities. In my experience, external hard drives can be particularly sensitive when it comes to unplugging the data cable while navigating the drive. I've had two external drives lose all data because of that flaw in the NTFS file system. The MFT exists on every drive with NTFS storage method. If that becomes corrupt, it can render the drive useless.
The drive may have power, but that quiet beeping you hear is an indication that the reader head is stuck to the platter and may be grinding into it. There is a myth (may or may not be true) that says if you put the drive in your freezer for a few minutes, take it out, drop it from 6 inches onto a hard surface, it may knock the head loose and make the drive work again.
I tried that method, and it made the situation worse for me, but it may work for you. I would resort to that option only if nothing else fixes it.
Posted on Aug 09, 2009
puku_07
  • 60 Answers
SOURCE: my external hard drive does not work on windows xp
reintall xp
and try again
Posted on Aug 30, 2009
  • 16 Answers
SOURCE: Hard Drive not recognized by laptop
The Hard Drive could have come loose from the SATA or PATA connection, or your Hard Drive could have simply died. If it is still under warranty; replace it. If it is out of warranty; open the external casing and check that the HD is connected and / or test the HD in a separate external casing or Desktop that you have. If it is connected and the external casing is working properly (or Desktop is booting properly and can read it), then you have a dead Hard Drive and will have to buy a new one.
Posted on May 03, 2010
My Iomega LDHD250U 250 GB USB External Hard Drive's Power and Usb ports WILLNOT CONNECT!!!!!!! Please help ive been trying to figure out why all day.
Dear Friend, Your I-Omega case might be bad or the controller inside that connects everything. I suggest you to get: http://www.walmart.com/ip/Apricorn-Universal-Hard-Drive-Adapter/10811435. and pulled your hard drive enclosure apart, then removed your hard drive and connect with the external adapter. Usually comes with a SATA or IDE connector for data and power adapter. After connecting everything plug into your PC and it should be able to recognize.
Good Luck#
Jan 13, 2014 | Iomega (33215) 250 GB Hard Drive
Blinking light on iomega external hard drive
Try plugging the unit into another working computer. If the same thing happens then the external drive is toast. U may be able to remove the drive with within the unit, set it up as a slave, install on working computer and possibly extract any and all needed files before throwing it out.
Nov 22, 2013 | Iomega Prestige 1 TB USB 20 Hard Drive
Starts to spin then stops
Either the power supply is failing, or the drive has gone defective.
Check with IOmega, it's probably under warranty.
If it isn't, open up the casing and see whose drive (ie, Seagate, Samsung, Maxtor) they used, because the drive itself may be under warranty by the manufacturer.
Before doing that though, connect the drive inside your PC and see if it works.
If it does, just permanently mount it in there because the external boxs' power supply is shot.
If it works in the PC and you really need it to be external, just buy an external hard disk enclosure.
They are about $30 in most places, and that'll FixYa right up!
Apr 11, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
My iomega hard drive Model No GDHDU has just stopped working the power light isnt on but the power lead is fine I CAN`T ACCESS ANYTHING PLEASE HELP
Your hard drive is not getting the power from the port u r connecting to. So please check it with other port . If the same behaviour then it is physically damaged and u have to take it to the service centre
Feb 01, 2011 | Iomega (33150) Hard Drive
My iomega 500gb external hard drive has a broken.
My Iomega (33654) 500GB USB isn't working. When I turn it on the blue light comes on for a few seconds. I can hear / feel it working but then the light goes off (it is still whirring inside). The computer isn't recognising it. I think it's still under guarantee but I can't find the paperwork. Do you have any ideas?
Apr 03, 2010 | Iomega (33654) Limited Edition 500 GB USB...
Iomega large external hard drive doesn't show up on computer desktop. All cables, ports, power source, etc. tested (standard troubleshooting process and testing with other functioning external hard...
Well this is a tough one. I am assumeing that you have done all the normal things.
Most external hard drives are just a standard internal hard drive with a case and a IDE/SATA to USB adapter built in. When you plug in the drive and it powers up listen to the drive if you hear a clunk. Not a the happy ticking of a normal drive but a bad clunk. This can mean that the controller on the hard drive itself is bad.
If everything sounds happy then I would try replacing your power adapter. I know that the blue light goes on but most of that runs off the 5 volt leg of the power supply (I have has some hardware manufacturers actually pull the power light voltage from the USB port Grrr) most of the Large sized external hard drives use a 12 volt adapter and it can have no problem with the step down to 5 volt it may have a problem with the 12v.The 12v is what it uses to spin the drive. Unless you have one of those little drives. They use a laptop hard drive that works of a lower voltage. Most of the time you can get an adapter from Radio Shack. Be sure to bring the old one so they can get the Volts, amps, poleartity and the type of connector. It is worth a try and keep the reciept. If it is just bad I am sorry but the only way to get the data off is to break into the unit and pull the hard drive out. Then use another USB to IDE/SATA adapter to pull the data off.
Hope this helps a little.
Sep 13, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega lphd160-u beeping
Your USB port does not have enough power to support the drive. You will need to use an external power source or try a firewire cable if the drive has that option.Travis Cable
Mar 29, 2008 | Iomega (33600) 160 GB USB 2.0 Hard Drive
No Power to External Hard Drive
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
Jun 21, 2007 | Iomega (33090) 250 GB Hard Drive
Iomega Prestige 1 TB USB 20 Hard Drive Logo
23 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
