Question about Cradlepoint MBR95 Cradepoint Wireless Router
MBR95 won't recognize AT&T Beam
I recently upgraded my AT&T wireless adapter. But the MBR95 won't recognize the AT&T Beam model AC34UBL
Windows 8 computer won't detect netgear n300
It might not need for WIn8 to detect the adapter. when that screen appears cancel/close of otherwise kill the process and see if the adapter is recognized in Device Manager without any error icons.
Aug 05, 2017 | NetGear WirelessN 300 USB Adapter WNA3100
Driver for Wireless Network Adapter apparently not working, said windows and the driver does not show up in device manager. Recently upgraded to Windows 7 Ultimate and the wireless option wasn't t
Remove Realtek wireless network adapter and upgrade to an Intel adapter. Check you tube on how to do the upgrade its very easy. The card is right under the keyboard.
Mar 23, 2012 | Toshiba Satellite A505S6014 (PSAT6U00J001)...
I have a Dell Inspiron Laptop. I recently reformatted it. Now It does not recognize wireless connections. I cant connect to the net Can anyone help?
When you reinstalled Windows, Windows probably did not include a driver for your wireless adapter. A driver tells Windows how to interface with a certain device, such as a wireless adapter. You can easily download the driver online and install it. Once installed, restart the computer and you should again have the ability to connect to wireless networks.
I've gone to the Dell website for you and found the correct driver. Please visit this link: http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&catid=5&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_PM_1525&hidos=WLH&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
On that website, I would first try downloading the first driver on the list. If that doesn't enable your wireless after a reboot, try the other ones. After the correct driver is installed, your wireless will be working again.
Jun 01, 2011 | Dell Inspiron 1525 Notebook
Netgear wna 3100 won't install on my windows xp. I have uninstalled it 3 times. It won't recognize the adapter. Then it does. Then in the end it won't recognize it even though it's there...
My adapter constantly loses connection completely to the router and cannont be re connected unless i unplug and replug back in the USB port. What a joke!?
May 06, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
I use a D-Link DWL-G122 USB Wireless adapter on my laptop, but I recently upgraded to Windows 7 and now the driver which was more for Win XP doesn't work very well. Is there a newer driver that is for Win...
you can try to see if there is a Windows & driver for your Air Plus adapter at the D-Link site if not use the windows compatibility feature to load the drivers for you device.
2. you can also use this feature :
Install and use Windows XP Mode in Windows 73.check the windows "help and support" link under the Orb in Windows 7 to get full instruction set to install and use Windows xp mode in Windows 7.
Apr 24, 2011 | D-Link AirPlus G DWL-G122 (DHDWLG122)...
Just upgraded from Windows XP to Windows 7 and the new OS won't recognize the Foxconn wireless adapter
Once upgrade was done did install driver for this card for windows 7. That might be your problem.
Jan 08, 2010 | Foxconn WLL-3350 802.11g/b (WLL3350)...
Upgraded from 9.04 to 9.10. After upgrade system
try running the restricted hardware application. under Settings->Admin->Hardware...
If not then go the the ubuntu forums, and use google to find the correct deb module for the hardware.
Nov 25, 2009 | Canonical Ltd. Ubuntu
Computer doesn't recognize device
remove previous all drivers for this device and install again, if not works , setup your OS freshly.
Sep 26, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Network connectivity - Intel PRO/1000 MT Adapters
One adapter may not support gigabit ethernet. Thats the reason.
Check the adapter.
Please rate the answer if its helpful to you.
Thanks
Jun 12, 2009 | Computers & Internet
USB mouse not recognized
I have similar problem. 2 inland KVM's (both have PS2 inputs, one has USB outputs) do not light or recognize my usb mouse with a PS2 adapter. They do recognize a PS2 ball mouse on the KVM's however. One of the computers (Sony vaio 1.5 GHz) does recognize a usb mouse with adapter on 2 other KVM's (Old Belkin and a Trendnet) (the second computer I have not tried in those configurations). Next I will try an optical mouse with a PS2 fitting. That did work with a fifth KVM at an auto business last week.
Feb 18, 2008 | Dell (582RR) 16-port KVM Switch
Cradlepoint MBR95 Cradepoint Wireless Router Logo
98 people viewed this question
Top Cradlepoint Computers & Internet Experts
S. Pankratz
Level 1 Expert
Prashant M
Prashant M
Are you a Cradlepoint Computer and Internet Expert? Answer questions, earn points and help others
