Question about Brother MFC-8460N All-In-One Printer
Ricoh sp4310n won't print beeps reads open front cover
2 Suggested Answers
  • 223 Answers
SOURCE: I am printing envelopes by
Thank you for using FixYa
This is a difficult question to answer with only one email when we can only read one text message you send to us, and we cannot see a responce after you make adjustments. There are some questions that we need to cover with you while you are feeding the envelope. Are you saying that you want it to print continous envelopes? If so, then you need to load multiple envelopes in the tray. What size envelope are you using and what do you have in your printer settings set for envelope size? That is where I would look first, and see if the size is the same as the envelope. The printer usually will have a sequence when you select envelope/manual print and prompt or wait for you to input the envelope, does it do that? I suggest that you come back into our chat option, so we can set up a conversation while you are doing this procedure.
I hope this was useful and please comment if this was helpful to you.
Posted on Apr 06, 2011
My company has a Ricoh Aficio SP4310N printer and it will not pick up or feed the paper in the tray. The rollers have been cleaned. The printer makes a grinding noise when it tries to print. Then i
when printer cant pickup paper may be shown this massage .check pickup roll.it may be scoured.raplace it .BUT if when you make power on comes masage check sensores. specially exit sensor.
Oct 06, 2017 | Ricoh Aficio SP 4310N Laser Printer -...
Ricoh troubleshooting
minimise this problem by creating half prints ie; whilst making a copy, open the front or side cover or even off the machine and than remove the jammed copy from within the machine to determine whether the mark is on the copy and drum itself. If it is than the probable cause would be the cleaning blade.
May 06, 2014 | Ricoh Aficio Office Equipment & Supplies
Missing print
machine needs drum and developer, but a temporary fix would be...open front door near notice green handle where toner is replaced, look to the right of green handle and down about 2 or 3 inches, you should see a plastic or chrome cover the size of a postage stamp, remove the cover and you should see a 3/4 inch wide piece of glass barely sticking out, carefully grasp the glass and pull it out of machine, wipe the toner off the glass , put glass back in and replace cover , shut front cover and run copies .
Jan 30, 2014 | Ricoh Aficio 2015 Copier
Ricoh 3000dn
1. The cover is open.
• Close the cover.
2. No paper in the tray
• Load paper in the tray.
3. The printer has stopped printing due to a major error.
4. The print cartridge is not installed.
• Install the print cartridge.
5. The life of the print cartridge.
• Replace the print cartridge
Apr 15, 2013 | Ricoh Aficio Sp 3300DN Laser Printer
Ricoh SPC400DN Getting frequent "Press A
It sounds as if it is not picking up the paper from the tray. It might need new feed rollers. Another thing to check is the lift arms on both sides of the tray. Make sure the springs are still attached to them. There is also a little switch on the left side front of the tray that adjusts the bottom plate pressure. You can try adjusting that to see if it helps.
Mar 12, 2011 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
How to open front cover for ricoh aficio c820dn printer as it is displaying message " open the front cover to check the paper jam"
Hi there !
You have to open the front cover means that you have to oper the toner compartment and check for the paper jammed inside.
Did it helps your or you find the paper jammed.
Jan 29, 2011 | Ricoh Aficio SP C820DN Laser Printer
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
Ricoh Aficio MP 161 is printing slanted duplex copies
Hello sir; There have two way to resolve this problem, 1st, loose the cover hinge push cover all the way to front then tighten it. then go to 2nd step open the top cover, at the left side of the white padding there have to lockes (up & down) open it out look inside there have a reverse roller, clean it with alcohal, hat should take care the problem.
Jan 27, 2010 | Ricoh Office Equipment & Supplies
How to solve error SC471 on my Ricoh 3800C
That is a transfer belt lift up error. The transfer belt lifts up for color and goes down for black only prints. Open right side door and check for paper stuck in the area near black rubber roller. Sometimes the belt dosen;t lift correctly. Open front door and turn knob on upper left counterclock wise to lower black transfer roller. On brown cover remove the top left screw and bottom right one (need to look on bottom side of cover) Slilde transfer unit out then back in. It is also possible the sensor inside machine is dirty.
Aug 18, 2009 | Ricoh Office Equipment & Supplies
Ricoh FAX2900L printing too dark
check the scanner white roller witch is under the front cover where you feed in the paper to be scanned sometimes this gets dirty you can take it out by releasing the levers on each side..this also sets the density for copying.. if you have just put a newe cartridge in also check that it is seated properly as the contacts for the charge might not be connecting properly
Nov 08, 2007 | Ricoh FAX2900L Plain Paper Laser
Brother MFC-8460N All-In-One Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
