Question about Whirlpool Duet GHW9150P Front Load Washer
Washer starts and then shuts off without washing clothes
Washer does not stay running
  • Gerry Harvey
    Gerry Harvey May 08, 2014
    Hi amy moran, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Sergeant:
  • 349 Answers
If it fills up with water then does not progress further then you need to first have the Pressure Switch assembly and its attached hose checked. This is the device which senses when the bowl is filled to the water level selected, turns off the incoming water supply and connects the power(via an internal switch) back to the timer so that it can progress into the WASH part of the cycle.
As always, I never suggest that an unskilled person attempts such repairs as you are dealing with water and 240volt AC which can be a LETHAL COMBINATION if mistakes are made and work safety rules are not followed to the letter. Leave it to someone qualified.
Posted on May 19, 2014
    Sergeant:
    Champion:
  • 271 Answers
Like Amy said, we need more info. do you see any fail codes on the display?, does your door locks?, do you hear any noises?.
Posted on May 09, 2014
  • 415 Answers
If it starts and fills then tumbles, and time has moved off the display then a couple of things if water remains in tub something has lodged in pump/or it has stripped, and or if no water and not spin cloths soaking wet then the door switch....
Posted on May 08, 2014
3 Suggested Answers
  • 6277 Answers
SOURCE: After washing -washer slowly fills with water and
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Posted on Mar 02, 2011
Testimonial: "Thanks- I felt sure water cannot get into the washer unless this valve is mal-functioning--checked price on Whirlpool site--$59.00--cut price to 56"
SOURCE: What is wrong with my whirlpool washer, it runs
your washing is damaged
Posted on Nov 17, 2011
Started a quick was cycle to test washer without cloths. It agitates for about 10 seconds, stops for 5 seconds and agitates for 10 seconds again. The light array is suggesting it is going from wash.
new washers usualy start a brief agitate then locks the door and then starts watering again. depending on washer model it can do this a couple times to evenly soak the clothes at the start of a wash cycle. it is advised to not run full cycle in the washing machine with no clothes for it can damage the unit.
Jul 07, 2016 | Whirlpool Compact Stackable Front-Load...
Duet washer , clean filter still get sud reading. Washes well without clothes. Wash with and without soap and did not put in clothes. The machine went throught the cycle with no problems. When you
do you get a lot of suds when you run it without soap and clothes ? if so put about a cup or 2 of vegetable oil into the washer and run a cycle . soap suds will adhere to the oil and it will help it to remove from washer . after you can run a clean cycle with bleach or white distilled vinegar.
Feb 20, 2013 | Washing Machines
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Water remains in the main tub of my GE washer and causes an odor
I myself would not run a minidisc in a GE washer. Only a Maytag.
Sep 08, 2012 | Audio Players & Recorders
My neptune washer will start and run about half a cycle and it acts like it gets stuck and on one cycle and never shuts off. I put a load of clothes in before I went to bed and next morning the machine...
What does half a cycle mean are you in Wash cycle, Spin Cycle? What does the Cycle Status LED indicate?
If you think the wash load is in a spin cycle of the wash cycle or rinse cycle place the machine in Spin Only cycle and see if it will complete.
Waht are your DIY skills? Do you want to try the repair/fix?.............Rich
Oct 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Ttt
Is this machine a front loader,I bet you have a clogged drain pump.
Try this with no cloths in unit put Draino-Max Gel. Add about 1/3 of bottle and let it stay in washer about 2-3 hrs. now shut door and start machine put on heavy-duty hot-water.this may take a few times,but this well take care of dog hair ,strings and also sanitize machine after. After machine starts to run better,bleach machine every other week.
Jul 26, 2010 | Whirlpool Washing Machines
My maytag front louder door won't lock or even stay shut?
it sounds like you have broken the switch which keeps the door latched when not in use as well as locks when the washer is started. These latches often fail when someone forces the door open to add more clothes without pushing the pause button AND waiting until the "locked" light goes off. Older children and teens and yes, uninformed men, are apt to do this. You will need a repair person.
Jun 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
CLOTHES STILL WET AFTER SPIN CYCLE
Dear dgloss1856, Sun 4-12-2009 1:14PM EST USA
Washers will shut down automatically without completing the spin cycle for two reasons.
1) Too many clothes in the washer at once (overloading with clothes) !
2) Too much soap in the washer when washing!
When this happens you should restart the machine in the spin cycle or if you can't start in spin run a full cycle without adding soap.
If this doesn't solve the problem you may need to clean the timer or control circuits depending on your machine by cleaning with electronic spray cleaner (available at Radio Shack) by spraying the timer or control circuits as instructed on the can of electronic cleaner.
cd1ee64.jpgLet me know if I can be of further assistance!
Apr 12, 2009 | Washing Machines
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Odor in Washer
You're probably using too much soap and softner and it's building up inside the tub. Run the hotest wash you have without any clothes in the unit and add a little bleach. If you see bubbles in the water when it's running that's excess soap you're washing out. Do it over and over until the water stays clear and then start using less soap. It only needs about a tablespoon for a full load.
Oct 27, 2007 | LG WM2277HSW XL Front Load Stackable...
Whirlpool Duet GHW9150P Front Load Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
