Question about Lands Phones
Touch tone dialing not recognized vtech phone
informatica
  • 1114 Answers
SOURCE: uniden tru448-2 rotary dial
You can download the manual from the link below: http://www.uniden.com/pdf/TRU448-2om.pdf To set tone dialing see picture below: Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 12, 2007
monotary
SOURCE: I can't dial out from my handsets
Here is something to try:
Disconnect or unplug the power supply (the small black box that is plugged into the wall outlet) wait for 30 seconds and then plug it in again. Sometimes the power supply needs to reset itself. It worked for me.
Thanks,
monotary
Posted on Jan 25, 2009
  • 95 Answers
SOURCE: My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
Posted on Mar 28, 2009
SOURCE: can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
Posted on May 13, 2009
  • 7993 Answers
SOURCE: phone went from touch tone to pulse. . .
Read the manual to reconfigure that option. (Look for Setup button on the phone) I can't guess what model you have. On older phones one could find a switch on the the phone to flip between Tone and Pulse.
Sorry I could not be of much help.
Posted on Sep 04, 2009
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Jul 31, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
Switch rotary phone to touch tone
Enter the model of your VTech DECT 6.0 phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
May 25, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
When I dial * on Vtech CS6114 it reads it as a 1. how do i make it recognize a *?
Sounds like your touch pad may be going bad. those freq are not ajustiable...
Apr 06, 2014 | Vtech Lands Phones
When I dial out on my Vtech phone, it goes back to a dial tone or a busy signal
Are you sure that the phone is even trying to dial? Push 1 digit and make sure dial tone is going away. Could be bad dial pad.
Apr 05, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
My Vtech cs5121 cordless phone has no dial tone
Vtech phones are junk! I have had many trouble calls for no dial tone,only to find out the Vtech phone is the only one they have,and it is defective.(It really DOES pain me to bill someone 91 dollars to tell them their 21 dollar phone is broken-always try another(preferably hard-wired) phone before calling the phone company!
Dec 30, 2012 | Vtech 5.8GHz Cordless Phone with Digital...
How to prgram the vtech 5.8 dial tone to touch tone
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Mar 05, 2012 | Vtech 5.8GHz Analog Cordless Phone
No dial tone
vtech are not very good u mite need another fone
Sep 09, 2009 | Vtech IA5854 5.8 GHz Cordless Phone
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
Dialing
Use the following steps:
1. Press the program button on the handset.
2. Use the up/down arrow keys until you see dial mode.
3. Press the select button and use the up/down arrow keys to change it to pulse.
4. Press the select button. You will hear the phone beep which indicates it has been changed.
Dec 26, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Phone not working
If the VTech is plugged into a different phone outlet than your touch-tone, then I know what your problem is. There are two wires that are hooked up inside the outlet box that run to the jack that your phone cord plugs into. One wire is for the "ring", the other one is for "tip". If these two wires are hooked-up backwards, it will cause you to have a dial tone whether you press any number buttons or not. Don't fret...it's an easy fix. If you pull the cover off of the outlet and reverse the wires meaning that if depending on which two are hooked up to the jack, whether it's the black and yellow pair, or the red and green pair, all you have to do is loosen the two screws that are securing the two wires that are going to the actual jack, and reverse them. Then just tighten the screws back up and replace the cover on your outlet. You should be ready to reach out and touch someone immediately! Hope this helps and have a great day!
Nov 23, 2008 | Vtech Lands Phones
Lands Phones Logo
15 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
