Question about Top Motor 50x50x20mm DC 12V Ball Bearing Fan Fan Kit
How do you add fluid to 1967 pontiac LeMans convertible top motor pump. Top will not go down but I can hear the motor running and can see bubbles moving in the tubes.
  • 97 Answers
You've got air in the hydraulic system, it needs to be bled. the fluid inside will not pressurize with air inside the lines.
Posted on Jun 18, 2009
My convertible top stop working want go up or down by switch
DO U HEAR THE MOTOR RUNNING AT THE LEFT SIDE REAR INSIDE THE BOOT ??? DOES THE YELLOW INDICATOR FLASHES WHEN U TRY TO WORK THE TOP?WHEN U UNLOCK THE TOP DO THE WINDOWS ROLL DOWN A BIT?IF U COULD LET ME KNOW SO THAT I CAN HELP U FURTHER MORE!!
Mar 09, 2014 | 2003 Volkswagen New Beetle Convertible
How do i check fluid for convertable top
"How do I get the air out of my hydraulic system"?
  • Remove the reservoir plug on the motor pump. Leave the plug out and do not put back until you have finished.
  • Fill the reservoir 3/4 full with fluid (to the bottom of filler plug hole). Put a rag under the hole to catch overflow that will occur as system fills.
  • Run the pump for 15-20 seconds. Stop. Check your fluid level and refill to bottom of filler hole. Continue running the motor in the same direction for an additional 15-20 seconds. When the top gets to the end of cycle, check your fluid level, fill to bottom of filler hole, and run the motor in the opposite direction.
  • You are literally running the top all the way up and down sereral times. Checking the fluid level as you go and fill as required, leaving reservoir 25% empty.
  • When you are no longer able to add fluid, put the top in the down position. Check the fluid level one last time, should be to bottom of filler hole. Put the plug into reservoir.
  • Apr 01, 2012 | 2004 Ford Mustang
    Mini cooper convertible top won't go up
    do you hear hydralic motor if not use test light while operating control switch up and down position, you need a helper for this procedure.if power is at switch, see if power at hydralic motor while helper work the control switch, if no power at motor hook test light to good ground if no power at hydralic motor check fuse.if power at hydralic motor and you hear no sound hydralic motor bad.if power going to control switch and not to hydralic motor either control switch bad or you have broke loose wire at switch going to motor.if all electrical system okay and when you work the up switch and hear hydralic motor running your hydralic fluid level low reason why convertible top not going up.check fluid level at the side of the motor and pump you should see screw type check plug.you should have see through side reservoir fluid level should be between min and max marks.if fluid is low check for leaks at the pump hoses and hydralic cylinders.
    Nov 27, 2011 | Mini Cooper Cars & Trucks
    Convertible top not going up.
    LISTEN FOR HYDRALIC PUMP MOTOR OPERATION IN THE TRUNK AREA..IF YES YOU HEAR HYDRALIC PUMP MOTOR RUNNING MAKING A NOISE.CHECK HYDRALIC PUMP FLUID LEVEL BY REMOVING THE SCREW TYPE CHECK PLUG.PLACE RAGS UNDER THE CHECK PLUG.AND UNSCREW REMOVE THE CHECK PLUG. FLUID SHOULD BE 1/4 INCH BELOW THE CHECK PLUG HOLE.IF FLUID IS LOW ADD FLUID UNTIL FLUID LEVEL 1/4 INCH FROM THE PLUG HOLE.IF HYDRALIC FLUID WAS WAY LOW YOU NEED TO BLEED AIR OUT OF THE SYSTEM.MAKE SURE FLUID LEVEL CORRECT.START ENGINE AND TRY RAISING AND LOWER THE CONVERTIBLE TOP USING THE SWITCH.IF TOO MUCH AIR GOT IN SYSTEM.HAVE A HELPER WORK UP AND DOWN CONTROL SWITCH WHILE YOU MANUAL OPEN CLOSE CONVERTIBLE TOP BY HANDS BLEEDING AIR OUT OF SYSTEM.KEEP EYE ON HYDRALIC FLUID LEVEL WHILE BLEEDING THE SYSTEM..LOWER THE TOP AND TURN OFF ENGINE. BEFORE OPENING THE HYDRALIC PUMP FLUID CHECK PLUG BECAUSE FLUID WILL SPRAY EVERY WHERE..IF HYDRALIC PUMP CHECK OUT OKAY AND YOU DO NOT HEAR NO HYDRALIC PUMP NOISE.POWER IS GOING TO HYDRALIC PUMP.EITHER HYDRALIC PUMP MOTOR FAULTY OR FAULTY HYDRALIC PUMP RELAY BEST TO LET MERCEDES BENZ DEALERSHIP CHECK IT OUT...
    Apr 30, 2011 | 2005 Mercedes-Benz Mercedes Benz SLK350
    1996 audi cabriolet 2.8 V6 convertible top motor needs fluid how do i add the fluid to the convertible top motor?! and what type of fluid does it need?
    Almost all power convertible tops are electric over hydraulic. The ecectric motor runs a hydraulic pump. The pump pushes fluid to the cylinders that work the top. Most are located behind the rear seat backrest. Either remove the rear backrest or access the motor/pump from the trunl. It will be shaped like a cylinder. At one is the electric motor, at the other end is the hydraulic reservoir. At the end of the reservoir is a rubber plug. With the top down, remove the plug and fill it with tran fluid till it over flows. replace the plug and cycle the top up and down as far as it will go. Repeat the process till it will take no more fluid. A turkey baster with a piece of vacuum line makes a good filler tool. With that said, you must find the leak. You may have a leaking pump, hydraulic line or cylinder. RNever replace one line. Do them all. Always replace cylinders in pairs.
    Good luck, Karl at aoksales.com
    Jan 20, 2011 | 1996 Audi Cabriolet
    1995 Jaguar convertable XJS quarter light windows wont go up
    The rear windows are controlled by a timer in the top's ECU. If
    the rear windows stop fully closing before your top is closed, the
    problem MAY be with top's hydraulic system.
    Check your top's hydraulic reserve tank for low fluid level. Lack
    of fluid will greatly delay the top's closing sequence, leaving
    those rear windows partially open.
    Your top's hydraulic pump system is located beneath the right side
    of the cubby/storage box behind the front seats. Raise the cover
    and you'll see a removable trim panel on the right side. The pump
    is behind that access panel.
    You can use power steering fluid to top off the tank, but don't
    fill it above level indicator line. You may have to add more fluid
    after you cycle the top up and down to get the air bubbles out of
    the lines.
    It could also be a relay. On a 95 the relays that are in the trunk above the battery.
    Perhaps, just switching the relays might prove which one is failing..
    Mar 24, 2010 | 1995 Jaguar XJ-R
    Convertible top goes down and won't come back up.
    You are probably low on fluid.
    Behind the rear seat is the motor/pump/reservoir.
    With the top down, fill the reservoir till it overflows with ATF. Cycle the system a few times. Repeat till the reservoir will accept no more fluid.
    Look for leaking lines or cylinders. The fluid must have gone someplace.
    Always replace lines and or cylinders in pairs.
    Jun 27, 2009 | 2000 Ford Mustang
    Throwing gas from unknown part
    If it looks like this it is the fuel pump,If not post a picture.
    Please rate this a fixya
    May 21, 2009 | 1988 Pontiac LeMans
    Convertable top wont go down..I hear motor running
    Your top motor is in the trunk on the drivers side wall behind the panel. Remove the two screws to remove the cover. Check the fluid level in the reservor. Check that no lines have come off of the pump and have someone pushing the top down button while checking. If this is not the problem, then it is a possibility that the e-brake connection is not working right.
    Dec 09, 2008 | 1998 Volkswagen Cabrio
    Top Motor 50x50x20mm DC 12V Ball Bearing Fan Fan Kit Logo
    301 people viewed this question
    Top Top Motor Computers & Internet Experts
    Alun Cox
    David Payne
    David Payne
    Are you a Top Motor Computer and Internet Expert? Answer questions, earn points and help others
