Question about Dewalt DPD3100 Gas Pressure Washer
Dewalt DP3100 Excess pressure stalls engine
When water flow is on and engine running. Pump builds excess pressure that stalls engine & locks up until pressure is released. It blew the valve open.
  • 95 Answers
SOURCE: compressor question
i have that compressor and had that problem. i build professionally so i use it alot. i had it about a year before the regulator quit working which is what yours is doing. i put it back in the box and took it back to lowes
please rate answer
Posted on Mar 21, 2009
  • 1383 Answers
SOURCE: Dewalt 4 gal air compressor will not build pressure in take.
The bleed valve is an unloader of sorts that allows the compressor to start with-out a load. It closes when the pressure in the airline reaches about 20-25lbs with good volume. If air volume is not sufficient, the valve will not close. To solve the problem lets do a few tests. A long cord will reduce power and reduce air volume. Try powering the compressor with-out extension cord. If bleed valve closes when you do not use a cord, the compressor is not getting enough voltage, use shorter cord of the 12 gauge quality and more hose to reach work. If valve still does not close, check for air leaks on all fittings including around pressure switch and drain valve with soapy water. Repair as necessary and retest. If no leaks were found, temporarily plug bleed valve port with screw/bolt and run compressor till set pressure cut-off while counting minuites/seconds. The compressor should fill and shut off within three minutes or so. If it takes an unusually long time to fill, then the reed valves /valve plate is worn and leaking pressure back into cylinger. Leaking valves will usually result in very hot discharge airline/air. Reinstall the bleed valve after test. Parts and partslist are available at www.toolpartsdirect.com . Good luck on the repair and email if you have other questions.
Posted on May 06, 2009
  • 23 Answers
SOURCE: Dewalt compressor will not build up pressure
turn on and tap the top of the pin lightly also with no air in tank pull up and down on pin spray lightly with wd40 never let anyone use this pin valve to release pressure it will ruin the valve if you still have problems you can get a new universal check valve off the shelf at lowes for around $6 make sure you use thread tape when reinstalling
Posted on May 12, 2009
boysor2933
  • 293 Answers
SOURCE: Dewalt d55141 Builds only 45psi
Check the unloading valve. Accumulation of dirt might be preventing the valve to fully close, by-passing a portion of the compressed air.
Posted on Jun 11, 2009
  • 5603 Answers
SOURCE: Relief value releases and will not reset
Likely the check valve is bad or has contamination on the seat. The result is the pressure will bleed back out the compression relief valve which is often as part of the pressure switch.
If the safety valve is the one that is bleeding, then the pressure is set too high at the pressure switch.
Posted on Apr 08, 2010
2003 volvo s40
worn fuel pump / low fuel pressure / engine management fault ?
Dec 23, 2013 | Cars & Trucks
Machine turns over, but keeps stalling when I begin to spray
By stalling you mean quit or bogs down until you release spray?
The engine has to be on high speed and be in good tune with good gas to produced the horse power for the pump. A too small water supply hose can add to to the engine load trying to suck water that is not there.
Sep 12, 2013 | Dewalt Garden
If I use a small amount of water, the pump starts, but does not build pressure. The pump continues to run and acts if it is air locked or lost prime. If I shut the switch off and let the pressure go and...
Sounds like a well pump with a leaky foot valve. I beleive you are correct in that it air lockes then when you shut it off the water flows back eliminiting the air lock.
Aug 07, 2013 | Shurflo Plumbing
Excess water out of back pump
Apparently this question is not about digital cameras, though that's where it's posted. Please repost in a more appropriate section of FixYa so that the proper experts can see it and give you an answer. It may also help if you could state the make and model of whatever device you're asking about.
Jul 17, 2012 | Cameras
Can't get nozzle to work. not building up enough pressure.
Make sure the injector is turned on. Clean the nozzle or the strainer if either are clogged or blocked. There may also be dried chemicals in the injector; dissolve them by running warm water through the injection tube.
Check to see that the faucet is open if the engine is running but the pump is not building maximum pressure. If the unit has been stored in freezing temperatures, you'll need to thaw it out completely, including the gun, wand and hose. There may also be air in the pump. Allow the engine to run with the gun open and the wand removed until a steady stream of water is released. In addition, make sure the adjustable pressure knob is set to the maximum position,
Clean the nozzle if the engine is overloaded, as the nozzle may be partially blocked. Reduce excessive pressure by using the pressure adjustment knob.
Jun 11, 2011 | Coleman Garden
Power washer will run fine for about 30 to 40 minutes then stalls, I wait a few minutes and starts but it runs rough and stops.
Sounds like a fuel problem eighter a filter or you have debrie in your fuel tank thats cloging the inlet from the tank to the carburtator . Its that or a problem with the water pump . That could also be clogging and putting exesive back prressure on the engine shaft causeing stalling . What dose your water flow look like do you loose that first before the engine starts to bog down or dose the engine go first and the pressure follow . Also do you winterize the mechine i owen and repair many washers if you need more info you need to give more pier_j
Feb 20, 2011 | Dewalt DPH3100 Gas Pressure Washer
Got a Dewalt 3800 PSI Pressure Washer with 4.0 GPM with a Honda GX 390 gas engine. Tipped it up to roll it out to my truck and got a big puddle of water with what looked like Pump oil in the puddle. Can...
Could very well be. Did you check the oil level and condition of oil? If its too full or if its light brown milky, then water has entered crankcase. Pressure washer pumps cannot stand to ever let run dry. Even a little. Also excessive idling will overheat pump if it doesn't have a thermostatic relief valve that allows some more cool water to enter pump.If it doesn't have one add one. Find your PUMP mfg and model number. IF it's pumping good now and no leaks, quick replacing the seals will save big future repairs. www.pressure-washer-parts.com has lots of info on many pump manufactures. Or get some seals from dewalt.
Aug 11, 2010 | Dewalt 3800 PSI Pressure Washer
When I depress the handle on the wand the motor wants to stall
sounds like you have either a sticky unloader valve or a blockage causing back pressure to pump causing excess load to engine,a possibility is to check the nozzle at end of wand incase there is a piece of grit there since engine runs okay with no load,another solution is to check venturi that is located beside outlet of pump that you connect hose for wand to for possible wear or blockage,hope this helps
Mar 30, 2009 | Honda Garden
Pump keeps running and excess water goes into the cup tray
check the level probe on side of boiler may not be facing down as it should or need to be replaced.
Nov 16, 2008 | Nuova Simonelli Oscar Coffee Maker,...
Dewalt DPD3100 Gas Pressure Washer Logo
41 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
