Question about Norelco Cool Skin 7775X Electric Shaver
Replaced battery shver does not work - Norelco Cool Skin 7775X Electric Shaver
Wrangler Hero Watch analog hands dont work after battery replacement
Remove the PCB and replace the AG4 battery in the analog quartz movement. The stem can be removed by pressing the small lever through the hole visable after the CR2016 battery has been removed. I think it uses a Y121 movement.
Jan 31, 2013 | Watches
Wont run at all - gradually faded and then finally quit all together
It sounds as if the inside of the shver is full of old hair and the like. It needs a good cleaning. SOMETIMES this does not solve the problem and the brushes in the motor could be bad. it is cheaper to replace the shaver than fix one.
Oct 21, 2010 | Norelco 7610X Electric Shaver
Replace batteries?
Panasonic uses a specialized battery inthir shavers that have prongs on the ends. These are used only in panasonic shvers. Panasonic does not and will not sell these batteries to the consumer. You can not replace the batteries in this model without sending the shaver to the authorized Panasonic repair center and it will cost you more to repair it than to buy a similar new model.
You may want to take a look at buying the updated version of your shaver. It uses the same foil and cutter and is VERY similar to yours. You wll find this model available at shaveroutlet.com. See link below.
http://shaveroutlet.com/shavers/foil-shavers/panasonic-es-sa40-wet-dry-rechargeable-shaver.html
Mar 20, 2010 | Panasonic ES 3042S
Dell inspiron 1300 does not see the battery
remove battery check if laptop works fine with ac adapter, if not then download the latest bios version first if fails then replace ac adapter. If laptop works fine with ac adapter. but cannot work with battery alone, download the latest bios then charge the battery for 6 hrs. if still batt not charging then replace batt. but as you mentioned you already replaced the batt and your still getting the same issue. replace motherboard.
Sep 24, 2009 | Dell Inspiron 1300 Notebook
Braun 7526 trimmer will not move to the up position
The trimmer is extended by the button on the opposite side.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 24, 2009 | Braun Syncro 7526 Electric Shaver
Watch new battery installed still wont work
First you have to check if the battery is on full power, as sometimes even brand new batteries are underpowered. Good battery should have 1.54 - 1.57 Volts of charge.
If battery is ok and watch still not working - get the battery out and clean (scrape) all battery related contacts with steel needle untill they are shiny. Use the dust blower to get rid of cmall dirt particles.
Replace the battery. Now the watch should work.
If the watch doesn't work after cleaning contacts, then this is mechanical fault and you will need watchmakers help.
Do not forget to rate, please.
Feb 03, 2009 | Bulova Watch
Radio does not work after replacing battery
replace radio ,sounds like you flashed the battery the wrong way around and you have killed it
Feb 02, 2009 | 2006 Kia Rio
Apc ups flashes red light to replace battery, but battery is new
i think by replacing the battery has not been the solution to the problem
u need to check the battery charging voltage when turned ON with main electricity, if no voltage present from charger, there is no question of battery getting charged and also once the battery is down with charge it may not re charge hence the indicator and alarm.
recomended to nearest service centre
Mar 26, 2008 | APC (BE500U-WEB) (BE500UWEB) UPS System
Norelco Cool Skin 7775X Electric Shaver Logo
26 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
