Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
The Oven won't heat up!
I tried to use the oven and i heard it "click" like it was trying to work...I then tried to use the broiler and the same thing happened..no heat from either...
  • 6,784 Answers
If the elements only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the elements plug into. If this is the case, replace both the elements and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Another reason, why the elements will not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
***If the elements check out ok and, the Infinite switch(if equipped) is in good condition, you will then need to replace the ERC(electronic range control). it has failed.
Posted on Jun 18, 2009
Oven made pop noise now won t heat
It sounds like the control board blew out. I have had a couple of these just blow like that lately. The bake and broil wont work. . Check for any bad wiring but the control board is most likely the culprit.
Feb 20, 2014 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Oven won't heat up, you can see a little orange light glowing and it heated a little bit, but now the light does not come on at all. Also, not sure this is a double oven, but it does have the broiler...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 15, 2011 | Magic Chef 9112 Gas Double Oven
My oven has increased only 65 degrees in almost an hour....what does it mean when it heats up, but SLOWLEY??
The broiler element on the top of the oven comes on during the preheat cycle to speed things up and then only the lower element keeps the temperature steady. One of those elements is bad, probably the broiler. Try using the broiler and see if it works. If not, you need to disconnect the elements from the oven and check them with an ohm meter. If gthe elements check out ok, then it must be the temperature sensor/thermostat.
Jun 25, 2009 | Frigidaire FEB27S5A Electric Single Oven
Wont' heat in broil or bake
check incoming electric first, pull it out and gain access to main wire terminal, With multimeter set to at least 250v AC , check your power across the wiring as such. black to white (110v), red to white(110v) and then black to red 230v. if that ok ok turn, then start ckin elements for continuty also there might be a thermostat( usually an 1 in. round component with 2 wires located right inbetween the elements that has gone bad, will show no continuity. ck that before electronic control the fact that its clickin sounds like the relays are workin properly
Feb 23, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
384 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
