Question about Samsung CLX3185 Printer
Transfer replacement How do you get in TECH MODE
I have a Xerox Phaser 6110 laser printer. When I try to print, I get Transfer Belt Error. When I go into the Troubleshooting Guide, it states that I get an Internal System Error. I have already tried to...
The "Transfer Belt" error shows up after the printer has printed 60,000 pages. At which time the belt needs to be replaced.
You can try resetting the count, which may clear the message:
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]2.
If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter6. Enter Password 19347. Arrow to Transfer Belt and press Enter.
The display will show Clearing Counts and then return you to the Tech Menu. Press exit several times to exit the Tech Menu and then power cycle the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 27, 2011 | Office Equipment & Supplies
Have a transfer belt error What to do?
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Apr 02, 2011 | Samsung CLX 3160fn All-In-One Printer
How to fix transfer belt error in my samsung CLX3160fn
3. Select Tech Menu
4. Select DataSetup
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
I was getting a message that the transfer belt needed to be replaced and I replaced it. But the message won't go away.
try this:
1. Press # sign; then 1934
2. Press MENU
3. Arrow to Tech Mode (not User Mode); press OK
4. DataSetup; move arrow to Clear All Memory
5. Clear All Memory; press OK
6. Choose coonutry; press OK; will erase and print out configuration report; clearing the transfer belt error.
This wipes out the counter on the Transfer Belt. Clear All Memory means all your settings are wiped out. This also reset all the counters EXCEPT the imaging unit counter.
Trust this helps. Please vote.
Dec 14, 2010 | Samsung CLP 300 Laser Printer
How can i order the transfer belt for a samsung clx3160fn
The part number is JC96-03611C. Though it might be difficult to find at a local store, you can find it online. Places like facsimile.com or printerbuddy.com stocks it.
After you remove the old one and replace it with a new one. The replace transfer belt error message will not go away until you clear the transfer belt count on your machine. To do this, you will need to follow the steps below.
3. Select Tech Menu
4. Select DataSetup
Nov 29, 2010 | Samsung CLX 3160fn All-In-One Printer
I need to reset the transfer belt counter Samsung ClX -2160
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Mar 09, 2010 | Samsung CLX2160 Multifunction Color Laser...
Replacement transfer belt on my Samsung CLX-2160 not recognised?
Dec 12, 2009 | Samsung CLX2160 Multifunction Color Laser...
My window is showing "replace transfer belt soon" what is that and where is it and where do you find a transfer belt?
When transfer belt count 60.000 image need to reset.
Transfer belt (and other consumables) reset follow this procedure:
1. go in tech mode:
Press consistently menu -> # -> 1934 -> menu
2. in tech mode find ->consumables counter -> transfer belt ->reset
3. after 20 sec. power off and power on
If this not help try this:
1.MENU # 1934 MENU
2.Tech Mode (not User Mode)
3.DataSetup
4.Clear All Memory
Oct 27, 2009 | Samsung CLX 3160fn All-In-One Printer
XEROX PHASER 6110 MFP REPLACE TRANSFER BELT MESSAGE
If you have replaced the Image Transfer Belt, and the printer still does not work, you will need to reset the counter. Xerox would not tell me how to do it, so I did some investigating.
3. Select Tech Menu
4. Select DataSetup
May 18, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Samsung CLX3185 Printer Logo
35 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
