Question about Epson Stylus NX400 InkJet Printer
How do I print envelopes
How do I load and print standard size letter envelopes on my Epson NX400
I found template on ms works for adressing envelopes but do not know how to set up, load and print
  • Anonymous Mar 25, 2014
    How do I load envelopes?
    Scholar:
  • 169 Answers
You will get an option to print envelopes either from the microsoft word or you can use the software provided by your printer vendor.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
Go to printers setting and set the desired priting which u need. or for a free diagnosis of ur printer visit.
  • Anonymous Jun 18, 2009
    go to printers setting and set the desired priting which u need. or for a free diagnosis of ur printer visit.
Printing envelopes misalligned
Check your printer settings. Make sure you still have the proper size envelope selected. Sometimes, the settings change back to factory default when doing maintenance.
Dec 15, 2012 | Epson Stylus NX400 InkJet Printer
How to manually change default page margin for Panasonic DP-2330?
oh my go to printer properties, right click, go to page set up change the settings hit APPLY BAM there ya go
Mar 07, 2017 | Panasonic Workio DP-2330 Printer
Dont no how to print on envelopes, they seem to be to long to go in where paper fits
When you open up your printer settings (got to printer and right click on properties), go to the advanced tab. In there you'll find various setting for print quality and paper sizes, choose envelopes. Make sure you insert the envelopes into you printer as specified on the printer.
Jan 08, 2010 | Epson Stylus Photo R200 InkJet Printer
How do you print envelopes on an Epson Stylus NX400?
To print an envelope in Vista, just open any document in Word, select envelope, (located under Home to the left). It will put you in the envelope program. You can type in any address and return address here. Also under options you can change the size of envelope. Hope this helps.
Aug 05, 2009 | Epson Stylus NX400 InkJet Printer
I am looking for instructions on loading envelopes
Try the link below, it's to a on-line user's guide for your printer. To the left you should see a list of subjects, just click the one that says "Load Paper" then click on "load envelopes".
http://files.support.epson.com/htmldocs/nx400_/nx400_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Aug 01, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
Trouble printing envelopes on kodak esp3 printer
Have you tried this procedure?
Loading Envelopes
You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
Important Do not use envelopes with cutouts or cellophane windows.
1 Remove any other paper from the paper tray.
2 Insert one or more envelopes into the right side of the paper tray with the print side down and
the envelope flaps on the right, pointing left.
3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
4 Leave the paper tray open while the envelopes are loaded.
If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printing envelopes
Open a MS Word Document, select 'Tools' then 'Letters and mailings' then 'Envelopes and labels...'
Envelopes and Lables dialogue box opens - ensure you are on the 'envelopes' tab
Then type your recipient address in the larger white box
for standard letter envelope (DL 220m x 110mm) - Insert envelope into Brother HL-2030 manual feed, with print side up, gummed flaps down and to the left side (bring gray plastic guides in close to secure).
Then select print.
I have found that during the feed, one end of the envelope gets a little bit crumpled but overall it's still a little bit more professional looking than my handwriting.
Jan 12, 2009 | Brother HL-2030 Laser Printer
Printing an envelope in cs3 on an epson stylus photo r1800
You can try using Microsoft word in printing on envelopes, it is easier. On my MS word>tools>letters and mailings>envelopes and labels>click on feed and use the fourth from the left option.
Load the envelope at the right side of the printer> the envelope flap should be on the left facing the printer.
Jan 25, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printer
This would depend upon the software you wish to use. For instance MS Word has an envelope printing utility built in. Access it through TOOLS > LETTERS & MAILINGS > ENVELOPES & LABELS, use the HELP feature to read help info on the settings required. If you wish to use a simlple text editor like Word pad, simply set the PAGE SETUP settings to reflect the media you are using; for instancce set paper size to ENVELOPE C5, and then the margins to something like Left = 60 Right = 100 Top = 80 Bottom = 50 Click OK and this will then mean when you print your document the text will be kept toward the center of the envelope. Change the envelope and margins to whatever suits you best. Slip the envelope into the printer (face up and flap to the bottom) and push the guard up. You should be good to go.
Mar 27, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
232 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
