Question about Intermatic EI200W Electronic Auto Shutoff Timers
Intermatic EI200 Timer doesn't work - Intermatic EI200W Electronic Auto Shutoff Timers
  • Intermatic Master
  • 5,089 Answers
Check wiring for single-pole timer:
http://waterheatertimer.org/How-to-wire-timers.html
Check if timer is rated for load... this timer is rated 1/4 Hp and will work with incandescent and CFL and small fan motors... but not rated to operate bathroom heater.
Use Spring-wound timer for heavy-amp loads like bathroom heater and 1-2 Hp motor loads
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#digital
Gene
Posted on Aug 12, 2014
2 Suggested Answers
SOURCE: I installed a new Intermatic timer, model #
If the dial does not rotate but manual override works, then the timer is wired incorrectly or polarity of line is reversed or you are connecting to 240Volt line instead of 120V.
1) You have wires from breaker box reversed with wires that goes to sprinkler solenoid. Switch black wires and see if that corrects problem.
2) Check that breaker supplying voltage is 120Volt.
3) Test if black wire from breaker tests 120V to ground wire, and test that white wire from breaker tests 0 volts to ground.
Open following links for additional troubleshoot and parts:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Posted on Jul 04, 2011
Fantech FD60EM electronic timer control makes a loud buzzing sound and does not operate the fan
This timer appears to be Leviton LTB60
Timer has 1 year limited warranty, evidently from manufacturer.
If timer is making humming sound, then it is defective, possibly receiving undervoltage on the line, or wiring installed incorrectly.
Switch noisy timer with one of the other timers, and see if problem follows the timer, or is related to the specific location.
Otherwise replace with LTB60 from Amazon for $24.
Or buy Intermatic Ei200 timer, or replace non-electronic with spring-wound timer such as 60-minute Intermatic FD60, or 30-minute FD30, etc.
Nov 18, 2012 | Fantech FD60EM Electronic Timer Control
How do I reset the intermatic EI400 light timer
Copy following link to identify Ei400 series programmable countdown timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#Ei200
Hold down ON/OFF button and fully press-and-release small round reset button using paper clip.
Keep holding ON/OFF button until display changes
This timer uses CR2 battery installed in tray below the buttons.
Reset timer after installing new battery.
If functionality is not restored after new battery install and reset, then timer has gone bad.
This timer has 1 year limited warranty through Intermatic for defects in workmanship.
Ei400 can be wired for single-pole or 3-way.
Timer requires no neutral wire since battery operates the timer and relay circuit
Nov 13, 2012 | Day-Timer Intermatic Ei600c Digital 7 Day...
Manual switch works timer doesn't.
Timer that worked before and stopped working: could be clock motor or trippers
New timer installation: possibly the wiring from breaker box and wire to Load are reversed.
Open following links to troubleshoot Intermatic timer.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jul 27, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have a 3 gang box: a is for hall light switch
Timer is not identified. Battery-operate timers wire differently than timers that require neutral wire.
For 4-wire battery-operated Intermatic EJ500, ST01C, and Ei600, Ei400 wiring:
http://waterheatertimer.org/ST01C-program.html#ST01C
For 4-wire Intermatic Ei200 series, KM-series, Ei500 that require neutral wire
http://waterheatertimer.org/Programmable.html#wire
Add a comment with model number for more specific information
Jun 19, 2011 | RTO Intermatic Digital 7 Day Wall Switch...
Clock works but timer doesn't turn off or on
push the manual timer arm, does it work that way, if so,, you need to reset the timer switch trippers,, here this will show you what I mean just scroll down to the tripper section, http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Jun 17, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Dosnt work
If display is scrambled, reset timer: Push reset button while holding down enter button.
If display doesn't show, check AAA batteries.
If timer still doesn't work, then Contact Intermatic.
8000 series comes with 1 year limited warranty
https://parts.intermatic.com/
Intermatic does not show replacement memory board for ET8000 series
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Intermatic ET8215C- 7-Day Electronic...
Pool pump cannot be turned off with timer switch. Pump runs constantly. I can turn off with breaker switch but not with switch on timer.
You posted under Intermatic EI200 series countdown timer.
Intermatic EI200 series is rated for 1/4 HP.
Check nameplate on motor for HP. Pool pump is probably 1 HP.
Open following link for countdown timer ratings:
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%20auto-off%20timers.aspx
Add a comment and say what kind of timer you are using and say specifically what you want timer to do, and I will locate correct timer for that specific need.
You can also add a contactor to the circuit.
Timer controls contactor, and contactor turns pump on-off.
http://waterheatertimer.org/Water-heater-contactors.html
Also take advantage of fixya expert assistance live.
Apr 04, 2011 | Intermatic EI220 Electronic Auto Shutoff...
Our Intermatic EI200W is 1 1/2 years old and it has stopped working the way it should. It turns on the fan unit, it runs for 5 seconds and shuts off, it can be re turned on but again it only lasts for 5...
The problem could be the Load and not the timer.
I discovered that if there is a problem on the circuit, that these electronic timers can malfunction.
Buy circuit analyzer from home center, test nearby receptacle that is on same circuit.
If there is a ground fault, for example in your light-fan-motor, you have to track this down with multimeter or some other testing device.
If the circuit is clean, and your electronic device has malfunctioned, then bad news: There are no repairs for in-wall electronic devices.
I test timers: 4-6% arrive defective. Many go bad first year or two. Some last quite a while.
Some programmable timers can be reset and the timer recovers.
Intermatic page below shows countdown timers.
Sample manual shows 1 year limited warranty for your product:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei200%20-%20english.ashx
If I can make a replacement suggestion:
Manual spring-wound countdown timer lasts for 10 years because it has no electronic parts.
I have three of these and they work without a problem even on circuits that have small ground faults.
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer, or any household problem.
Jan 05, 2011 | Intermatic EI200W Electronic Auto Shutoff...
Replacement Cost
For a pretty simple work it should cost something like 200 dollars. For a more complicated work it can get to around 500-600 dollar.
Aug 27, 2008 | Intermatic EI200 Electronic Auto Shutoff...
Intermatic EI200W Electronic Auto Shutoff Timers Logo
80 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
