Question about Kitchen Ranges
Defy wiring dtd242 tumble dryer connection of thermo swithes
  • 139 Answers
SOURCE: Defy Tumble dryer not heating
Is this an electric dryer? If so, the most common problem would be a burned-out heating element. There could also be a defective temperature sensor inside. This will need to be evaluated by a qualified appliance repair technician to find the exact cause.
Posted on Jan 18, 2008
  • 172 Answers
SOURCE: Tumble dryer not heating
Hi irshaad,
If all the componants are good, you are loosing voltage somewhere. Check the voltage to the dryer. If you do not have 220 volts then you have a blown fuse or a kicked breaker in your fuse box. This would allow only 110 volts to get to the dryer and the dryer would run and not heat. If you have the correct voltage to the dryer check the connections on the terminal block and the wires to the block. Before going any further than that I would really rather have your model so I could guide you correctly. Good luck and I really hope this will FixYa.
Mike Anderson
Posted on Jun 03, 2008
localwonder
  • 6784 Answers
SOURCE: Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jun 22, 2009
protek480
  • 1723 Answers
SOURCE: got a Defy tumble dryer but it's not spinning.
Watch the video to see how to replace belt:
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 17, 2009
marka19
  • 1430 Answers
SOURCE: I am looking for a diagram that shows the correct
Try this link http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5173996&diagram_id=1345233#d1345233
Posted on Oct 05, 2010
Defy Tumble Drier DTD 252 wiring diagram
Request the wiring diagram directly from Defy.
Dec 10, 2017 | Dryers
Wiring diagram for dtd313 tumble dryer
Here is a possible. I know this is where it is located on some of their driers. Disconnect dryer and in the back of dryer in top left hand corner is your diagram, looking from back of dryer, just remove the 6 screws from the top panel at the back of the dryer. Most appliances have them tucked away somewhere on the equipment itself
Apr 15, 2016 | Cell Phones
Where do I find the capacitor in a defy tumbledrier model DTD242
Capacitors are used on the motors to add additional starting torque. If your dryer has a cap, it will be on or near the motor. Dryer electrical elements do not have caps: they are resistive.
Oct 22, 2014 | Dryers
Why does my Zanussi td4212w tumble dryer work but no heat?
check continueiy in the ellement and the thermostat
check the thermo with out 1 wire on........cheers
Jul 18, 2014 | Zanussi Dryers
Dryer wont heat up on a aquarius VTD00, do you think its the element
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. . Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. Also overloading and blocked filters can lead to thermo cut out, it is best to check your manual and call someone out on this occasion. You may even have a red reset button on the rear of your machine some models do, if yours doesnt then call out engineer :)
Jul 19, 2009 | Hotpoint NWXR473EV Dryer
Dryer is working but wont tumbel
This does sound like the belt has broken. Is the Defy autodryer the one that made the sound and then stopped tumbling?
Nov 11, 2008 | Dryers
Hi irshaad,
Mike Anderson
May 25, 2008 | Dryers
Jan 18, 2008 | Dryers
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
