Kenwood washing machine E3 error
It's making a grinding noise but the drum will not turn
  • 11 Answers
SOURCE: Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Posted on Feb 18, 2007
the dr
  • 447 Answers
SOURCE: grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Posted on Oct 04, 2007
IrishDruid
  • 2712 Answers
SOURCE: Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
  • 42 Answers
SOURCE: Hi I have a Whirlpool 6th Sense Washing Machine -
hi,
looks like there is some friction between the main and outer tub of your machine. there is generally a mechanism for smooth spinning of the machine in good rpms for wash-spin cycle. this could be because of rust formation, or mud collection. please refer your manual and remove the 3 screws behind the lower front plastic cover, and look for rust formation. scrape the rust and try spinning again.
cheers
Posted on Jul 26, 2009
  • 27 Answers
SOURCE: The washing machine started making a grinding
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Posted on Jan 15, 2010
Machine fills, then on entering wash cycle makes loud grinding noise kinda like a dull hacksaw on rusty metal.
Does it make the sound when you turn the drum by hand? It could well be the drum bearings that have gone.
Aug 01, 2016 | Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
Why Is my Maytag washer making a loud grinding noise?
Possible Drum barrings failure. Drum unseated making contact with Housing. switch off. turn drum by hand check it is free of obstruction.
Not a job I would recommend for a DIY enthusiast. unless housing is out of place obstructing drum.
Incidentally. if this is a brand new machine. ensure all the drum transport fixings (if aplicable) were removed, and not fouling the drum.
Aug 25, 2014 | Maytag Washing Machines
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
Grumbling Noise on Spin Cycle
If there is any form of grinding at all when the drum is turned than the rear bearings in the machine is going bad. This will only progress an get worse, then eventually start leaking and grinding and finally lock up.
Apr 26, 2012 | Bosch Washing Machines
Machine is making clanking and grinding noise during wash cycle drum does not appear to be turning. does not make this noise if ran without items in wash and drum turns with no items in the wash
You may have a problem with bearing. Place your hand inside the drum and see if you can move it up and down. If the drum can be moved up and down, you have a severe bearing problem that will require a technician to tear down the unit and replace the bearing and drum assembly. It's a very expensive job.
Good luck
Jun 16, 2011 | LG WM0642H Front Load
Kenwood washing machine display showing E3
e3 means there was a longer heating time but not reaching required temperature could be a malfunction of temperature sensor or of heating element.
Please do rate my solution also do post further comments if any help needed.Good luck with the machine.
Apr 08, 2009 | Washing Machines
Open Questions:
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
