Question about JVC TV-13142W Television VCR Combo Video Cassette Recorder Player 13 Television White
No sound for cable channels, do have sound with VCR
How do i set up my tv with my sony vcr
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
Sep 14, 2015 | Toshiba 24AF42 24" TV
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
I am trying to connect the vcr to the tv with a cable box
There are two ways to connect your equipment.
1) Connect the cable box antenna output (may be labeled "out to TV", "antenna out", "catv out" or even something else, but the key is it will say "out") to the VCR's antenna input. From the VCR's antenna output (out to tv, etc.) you connect to the TV's antenna input. For these connections you use RF cables, the kind with something called F-connectors on the ends. (These cables are available with screw-on or push-on type plugs. Use the screw-on type which makes a more reliable connection.) Set your VCR and TV both on the cable box output channel. This will be either 3 or 4, depending on how the box is set up. With this setup you can record whatever program is coming from the box by having the VCR record on the box output channel. Unfortunately, you can't record shows that are on different cable channels unless you'll be there to change channels on the box. (There are some VCRs that can control a cable box to switch channels, but I don't believe your model does.) You also can't watch one channel while recording a different one.
2) (This won't work if your TV doesn't have a video input available.) Connect the cable box to the VCR and the VCR to the TV with audio/video cables. These are the ones with RCA plugs, color-coded red and white for right and left channel sound and yellow for video. Set the VCR to line input and the TV to the input you have the VCR connected to. This connection setup gives a better picture and sound quality that the RF connection described above. You still have the same restrictions on recording, though.
Sounds a little confusing, I know. Just remember that inputs connect to outputs and you'll be set up in no time.
Mar 30, 2009 | Hitachi Televison & Video
VCR will not record with new digital cable box
The short and simple solution is to tune the VCR to the channel that the cable box is set to (4), and then tune teh TV to the VCR's output channel (3). If you do this you should be able to see the Cable channel through the VCR tuner and then record. Any other solution would require figuring out how to set both the VCR and the cable box to the same channel, but it sounds as if you have ruled out any possibility of being able to do that.
Feb 18, 2009 | Emerson EWV403 VHS VCR
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Proscan vcr psvr70
Sounds like it's wired up wrong...try this:
take cable line to VCR in, VCR out to cable/receiver box(if you have one) then box to TV...it sounds like the vcr is getting the channels from the box and not the vcr...you will need to have the vcr scan the channels (round in the settings menu) You will also be able to watch and record 2 different things.
Oct 18, 2007 | Proscan PSVR70 VCR
VCR tuner cannot tune in my cable channels
It is working as designed. The purpose of your cable box is to take in a wire containing all of the possible channels you might watch, and then extract *one* channel, and force it to appear as channel 3. If you connect the cable directly to the VCR, then the VCR's "tuner" (ie, channel selector) has an opportunity to extract any channel it wants. But... as you point out, your VCR won't be able to "see" any of the digital channels. So... if your goal is to be able to watch any of the digital channels, the signal must pass through your cable box, which will put the selected channel on channel 3. There is no value in going from the VCR to the cable box, since the VCR's tuner will have already filtered out all but one channel. It would be helpful to make a list of what your useage goals really are, since there are so many different ways to hook these things up. Are you interested in: - watching digital channels? - recording digital channels? - watching one channel while recording another? - using higher quality video signals (composite, s-video, component, etc) rather than RF (ie, channel 3) And so on. Keep in mind that you have *three* tuners: Your cable box, your VCR, and your TV. It sounds like only your cable box can tune in the digital channels. If your cable box puts out any non-RF signal, then the best choice would be to go: Coaxial Wire -> Cable Box -> Video Connection -> VCR -> Video Connection -> TV, with the VCR and the TV both set to "video". Then you would only use the cable box as a tuner, the VCR would only see the tuned channel (via video in), and the TV would see the same channel (or whatever tape you are playing) on its video input.
Mar 29, 2007 | Zenith VCS442 VHS VCR
Connection
Ok If you are connecting the VCR through the cable or antenna fitting on the TV set, you will have to see what channel the TV set has to be on. Look at the back of the VCR at the RF output and there should be a small channel switch. You also must tune the VCR in to recive cable channels unless you are using a cable decoder box. Good Luck
Mar 26, 2007 | Samsung SV5000W VHS VCR
JVC TV-13142W Television VCR Combo Video Cassette Recorder Player 13 Television White Logo
24 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
