Question about Harman Kardon HK595 Computer Speakers
My ALTEC speakers make noise when they are idle.. I shut down my computer.. re-start it.. then the speakers are not making noise but after a few minutes the noise returns .
  • shlomo15 Jun 18, 2009
    I took out the wires and reconnected them.. so far so good.. but we will see what happens after a period of time
There may be some problems with the wiring. either change the whole wiring or try to keep the speaker volume at low when they r idle. it will certainly help .
Posted on Jun 18, 2009
  • Anonymous Jun 19, 2009
    if the wires are intact, then i would advice to low the speaker volume when its not in use.
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
Makes a loud noise when i turn on and no sound plays. I don't think i need drivers but either way they're impossible to find. I have Altec Lansing ADA215 Computer Speakers.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 31, 2010 | Altec Lansing ADA 215 Computer Speakers
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
The big speaker make noise by itself!!!
Don't think the difference of 18/22vdc would make the noise. Is the noise constant? maybe too close to another device like a microphone or a something that would give off radio waves. Cell phones and cordless telephones. wireless gateways/routers. Try moving speakers away from these types of devices.
Oct 04, 2009 | Altec Lansing AVS 300 Computer Speakers
M602 Speaker Problem,.. Popping Sound
This worked for me on my M604: Try inserting/removing a headphone plug into the jack several times to see if that clears the problem.
The "popping" sound is very similar to the sound that the unit makes when inserting headphones into the 'headphone' jack on the back of the unit.
The jack has a contact switch that triggers a relay inside the unit. If that contact switch is 'on the verge' of making contact, slight temperature changes may cause deform closer to it's contact target. The subsequent capacitance build-up and discharge across the gap could explain the cycle of popping noises after the unit warms up.
Jun 25, 2009 | Altec Lansing M604 Computer Speakers
Subwoofer makes a sound at computer startup
1.yes the electric shock can damage the subwoofer  2.some times a sudden switch off or power cut can result in for such issue . 3.for this issue just make sure that you switch on the speaker 1st before starting the PC, then switch on the PC, & while closing time also make sure you 1st switch off or shut down the PC 1st & then the speaker in last   & more ???...! do keep on writing untill then have happy computing sir...till then See you soon...!
May 24, 2009 | Altec Lansing VS2221 Computer Speakers
Subwoofer Emits a Buzzing Tone
The 2200 uF capacitor in the power supply has gone bad and the humming is a 60 Hz from the rectification of AC to 18 vDC.  Either get a new power supply or take apart the power supply and replace the bad cap.
Mar 16, 2009 | Altec Lansing AVS 500 Computer Speakers
Scratchy loud noise when volume dial is turned
It means that the volume pot is dirty.You need to find a way to get some WD-40 into the pot.This usualy requires that you take the access to the inside off and spray right inside the pot.Once you do this move the volume dial from min to max a few times and it should fix it.
Jan 05, 2009 | Altec Lansing VS2221 Computer Speakers
I have altec lansing speakers AVS500 and have no sound
It sounds like the subwoofer speaker has blown. If you are comfortable working with a soldering iron and speakers then you can open the case and replace the speaker with a replacement subwoofer speaker. A good online store for replacement speakers is PartsExpress.com
Dec 28, 2008 | Altec Lansing AVS 500 Computer Speakers
Harman Kardon HK595 Computer Speakers Logo
198 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
