Question about Dryers
Mistral 4kg tumble dryer
Silver bracket inside the dryer
2 Suggested Answers
  • 5 Answers
SOURCE: inside dryer silver flaking off
If you need a new drum. Follow the instructions below.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Posted on Apr 02, 2009
Which of the 3 sensors on the back of the tumble dryer is used to sense how dry the clothes are?? mine some times cooks the clothes.
THERE ARE USUALLY 3 SILVER METAL STRIPS LOCATED ON THE INSIDE OF THE DRYER DOOR THAT DO THAT
Mar 14, 2015 | Dryers
The water light full light keeps coming on and the tumble dryer it stops working but the container has very little water in. it's a Candy GOC580C
SOUNDS LIKE A BAD MOISTER SENSOR USUALLY LOCATED INSIDE THE DOOR PANEL AT BOTTOM, LOOKS LIKE 1 LONG LITTLE SILVER THINGYS
Dec 17, 2014 | Candy Dryers
How can I get access to the thermal fuse in a
I believe tumble dryers have 3 thermostat fuses, they look like silver buttons, one on the back panel in the middle of the heating elliment, one in the ducting box for extraction and one somewhere else..I think.
tumble dryers are very empty inside, as long as its unplugged (I\'m an idiot.. 1 time) remove the back plate and have a look, if you need to unclip the wires inside to remove the panel, take photos so you know where they go back
Sep 23, 2014 | Dryers
Just brought a GVA 4kg dryer and it won't tumble?
Hello Linda, You didn't say if this dryer is brand new or used. If it is new, it should have some sort of warranty. If it is used, the most common cause for it not to tumble is the drum belt is either broken or off of the motor pulley.
Jul 08, 2014 | Dryers
One of the "fins" inside the dryer is coming off and just needs to be tightened but I cant figure out how to get to the drum to tighten the screw.
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum, but you have to remove the front panel first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. The baffles securing screws can now be re-tightened. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Sep 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you open the top? the padals inside the drum are coming loose
The front panel needs to be removed first before the top cover can be lifted to the rear of the dryer to access the outside of the drum and re-tighten the screws attaching the baffles to the drum. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Aug 01, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Removing top of dryer to get to the drum
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum. But before that, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
May 24, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Is it possible to mount the unit upside down on wall brackets, and of course, the dryer still operates satisfactorily? As there does not appear to have pressed openings on the rear panel for bracket...
Hi Don.
All appliances must be installed, used, and also transported and stored with the top side up.
If the dryer is turned upside down the weight of the drum, motor and other parts will not be sustained anymore by the rollers and other structural parts located inside the appliance.
The dryer will start, but it will break down after a short usage.
There are also other safety issues involved.
The dryer cannot be installed upside down.
Regards.
Feb 26, 2010 | Hoover Dryers
Dryers Logo
Top Dryers Experts
