Question about Philips AZ2555 CD Boombox
Won't connect to pc
When i plug the usb cord into both and turn it on to the pc link option, my computer does not connect the stereo, I have tried everything to try to get it to work such as:
unplugging the cord then pluggin it back in
turning the stereo off then back on,
installing the drivers,
downloading the drivers and updates,
using a different usb cord,
wiggling the connection cord,
restarting my computer,
trying to install it manually,
calling customer service...
and I don't know what else there is to do
Re: won't connect to pc
YOU DON'T NEED A USB CABLE!!! Buy a cable that has a red, white tip on it and a headphone tip on the other end then plug the red, white cable infront of the boombox. Then plug the headphone tip into the back of the pc where you would plug in regular computer speakers into it.
I don't know the exact name for the wire but some portable dvd players contain them.
I never used a usb cable too much trouble.
Posted on Dec 15, 2008
I had the same problem latelly and i uninstalled the driver and re-installed it and it worked...good luck
Posted on Nov 27, 2007
0 characters
3 Points
Why is Philips Boombox not working from mains without batteries?
When you plug a cord into a two pin connector that I assume is on the side of the box, it should disconnect the batteries inside. If taking the batteries out kills the power completely with the cord still attached, then the switch on the power socket in the unit is NOT connecting the built-in power supply.
Feb 15, 2015 | Philips CD Soundmachine Portable AM/FM...
Convert vinyl to mp3
There are a number of record players with included software that can be plugged into a USB port, but you could also use any HiFi and connect the audio output to the microphone input of a PC -- most likely with a cord with two RCA jacks to a stereo mini phone plug. The free Audacity software can record, filter, normalize and save the output to almost any audio format.
Oct 19, 2014 | Boomboxes
I have the Sony S2 Sports ZS X1 and it will not turn on.
Before confirm transformer fault, load batteries and see whether it works. After loading batteries, pull out its AC cord from its AC socket at it back side. With AC cord connected at the back of the set, battery supply won't connected to the set. There is a cut - off switch at the AC socket. Only after removing the AC cord, the set will work on battery.
Try this. If it works with battery, make sure that transformer or internal mains fuse has blown out.
May 29, 2012 | Sony S2 Sports ZS-X1 Radio/CD Boombox
No power on my JVC Kaboom
I would rule out the power supply simply because the batteries won't run it either. The internal plug that takes the cord should be checked for cracked solder joints, because the plug goes to battery mode when cord is removed and AC fuction when cord is plugged in. It is possible it may be an audio output problem given the age of the item.
Feb 12, 2012 | JVC KABOOM RV-NB10 Boombox
Can I get a cable to connect to the philips az2555 usb port and to my i pod?
  • HI, I can help.
  • No, you cannot run an IPOD to this. You can put music on this stereo from your PC after downloading the software from your computer to this stereo and then the stereo will act like an IPod/MP3 player but a physical IPod cannot be hooked up to this stereo.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 20, 2011 | Philips AZ2555 CD Boombox
I need a new power cord for a Hello Kitty CD Boom Box
These usually use a standard figure 8 cord (plug that goes into stereo is shaped a bit like a number 8).
You can buy these from most big hardware stores and places like maplin or tandy are also a goof bet.
Ebay will also be good and probably cheaper.
Jul 12, 2010 | Sanyo Hello Kitty CD201 Cassette/CD...
I need a new power cord for my Lenoxx stereo cassette/ CD player model #CD-102. I hope I am sending this the right way, I am not very good on the computer.
if it is a plugin (socket at the back of the stero) then you need to call the vendor to order the power cord. if it is a build in (internal connected) then you can get any power cord and repair it by opening the stereo and repair the cord.
Oct 20, 2008 | Lenoxx Electronics CD-102 Cassette/CD...
Need to order electrical cord for cd player
you can buy at the hardware..or best buy... it does not so complicated..
Sep 03, 2008 | Sharp QT-CD210 Cassette/CD Boombox
Philips AZ2555 CD Boombox Logo
735 people viewed this question
Top Philips Boomboxes Experts
Jonathon summesfield
Are you a Philips Boombox Expert? Answer questions, earn points and help others
