Question about LG Refrigerators
Lrbn20510ww not cooling
Neither section cooling / refrig section seemed to cool first / compressor runs about 20 seconds then quits
Master_Tech
  • 770 Answers
SOURCE: not cooling
The clicking you are hearing is your overload on your start system sounds like your compresser start ststem is out..or your compresser is locked up the only way to tell is to ohm out the compresser idf you dont have a meter you can install a start kit like a Supco Pro41 or a RCO410 or a factory replacement and see if it starts up the compresser.. Have you cleaned the condenser at all ??? although this will not fix the compresser it can be a cause of overheating..The part Number you need is a 2188831 for the factory replacemenet ($22.56)the supco parts part number SU RCO410 ($15.00) the Pro41 is part #
SU PRO41 ($17.97) you can get them at your local parts house they are all easy to change or if you dont have a parts house close you can oder it on the web at www.apdepot.com Hope this fixes ya
Posted on Feb 17, 2008
  • 142 Answers
SOURCE: Every 2 mins the compressor tries to go on and after 15 seconds stops.
If the compressor tries to go on every two minutes, then the relay is functioning.
1. If the compressor has failed, it might be getting hot and tripping the thermal overload to shut itself down. It will cycle like you say and will be unable to cool the fridge.
2.It's also possible that you have lost refrigerant from the system. When the compressor goes on, the pressure drops below a threshold value. The system sees that there is not enough pressure, and shuts down. Once the pressure rebuilds, it tries again.
3. If the fins in the rear of the fridge are clogged with dust/debris, the system will not be efficient enough to cool. I doubt this is the case as the compressor would generally just stay on for a long time... longer than 2 minutes.
Try turning the thermostat to the coldest setting possible for both the fridge and the freezer. If the unit still cycles off after 2 minutes, consider repair.
Posted on Mar 14, 2008
  • 116 Answers
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
Posted on Aug 01, 2008
  • 306 Answers
SOURCE: not cooling, compressor kicks in for 3 seconds then back out
No the PTC relay on the compressor is bad. Need to replace it.
First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Apr 05, 2009
woodchuck789
  • 4059 Answers
SOURCE: My GE refrigerator GDS18LBPWW with freezer on
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The ideal temp for the freezer is around 10 degrees F.
Look at the evaporator coils behind the rear cover inside the freezer and check the ice forming on the coils.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM
Posted on Dec 29, 2009
Have a kitchen aid side by side refrig that stopped working tonight. Model KSRB25FH with ice maker. Noticed ice was wet earlier today and tonight food has thawed in freezer section and refrig was not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Microwave Ovens
I have a frigidaire side by side #FSC23LR5JM2 that is not keeping cool enough. Age is aprox 1.5 yrs. Noticed the problem over a couple of days. Turned the temp cooler by 2 numbers in the frig and freezer,...
if the freezers staying cold but not the refrige section,then its the damper vent door between the freezer and refrige section thats either frozen shut or the damper door motor is bad or without power,if nothings cold as in freezer and refrigerator sections,then its the ptc overload & relay on the compressor thats bad,unplug the ptc overload & relay off the side of the compressor and obtain an exact replacement and plug in the new replacement and it will again cool
Mar 23, 2011 | Frigidaire FRS3R5EMB Side by Side...
Both refrig and freezer won't cool. the compressor has power but doesnt seem to get warm or hot. I think it is suppose to.
unplug the frig, then wait about 20 min.. to let compressor cool down. then plug back in..wait to see or look at compressor..see if you can see or hear it start up...if not..good chance you compressor has failed....
Dec 19, 2010 | Refrigerators
I have a lg frige model #lrbn20512ww. it quit cooling both upper and lower yesterday. are there any known problem with the compressor or could it be somthing else. the compresor runs for about min the...
unplug the ref remove the back panel place a fan behind the ref to cool the compressor when you can place your hand on the compressor then you can clean the condenser coil and plug it back up make sure the condenser fan motor is running
Nov 18, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
Dec 04, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
We have a GE Monogram side by side built in ZISB40DM, 48" with dispensor. We are having problems with the compressor heating up and the colling fan to the compressor not going on. Also, when you...
just check the wiring running to the fan and if you can, connect the fan direct to mains to check the fan itself is ok. no fan then the compressor will get hot and cooling will be affected.
the hot strip between the doors is deliberate - it stops condensation
Aug 23, 2008 | Refrigerators
Refrigerators Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
