Question about Dometic Rooftop RV Air Conditioner
Travel trailer compresser stops and starts
Compressor starts and turns off continuously
    Genius:
  • Dometic Master
  • 1,363 Answers
Try and replace cpacitors.
Posted on Aug 16, 2015
3 Suggested Answers
  • 127 Answers
SOURCE: THERMOSTAT TURNS FAN ON AND OFF, BUT COMPRESSOR
There is no fuse near the compressor on the roof. The only thing on or near compressor is the thermal cutoff switch either located on the top of the compressor or the side (depending on the model). You can check the thermostat rather easily with a 12V Test Light (available at most automotive stores) or a voltmeter.
Take the face plate off of the tstat. You should have a 6 wires or so (again, depending the model or part number of the unit and the tstat). If you turn the thermostat to high/cool, the yellow from the thermostat should have power to it. This is the cool setting. If there is no 12V going to the yellow wire, then you have a bad thermostat. If there is power, then you need to get up into the control unit of the AC and see if you have power at the yellow wire there. If you do not, then there is a problem in the wiring in the wall. If there is power, then you may have a bad control board.
There is a relay on the control board that controls the compressor. If you turn the unit to High/Cool and you do not hear the relay clicking, then you have a bad board.
You may want to get a tech to take a look at it, it can get complicated.
Hope this helps,
Jeff
Posted on Jul 03, 2009
ercupa190
  • 12223 Answers
SOURCE: hi,I have a travel trailer 37ft. Problem with my ac, the fan starts good but my compressor does not kick on. My next door neighbour says it's the compressor that is done. Could you help me?
see this causes and fix it. God bless you
Motor Trouble Cause Diagnostic Procedure Repair Procedure Electrical Power is Off Check that all service switches for the equipment are in the "on" position.
Check for voltage at the pump motor or pump controls. If no voltage is found, check for voltage at the electric panel.
If power is on to the building, check fuse or circuit breaker serving the electric motor that won't run.
Check for local reset button on the motor (popped out = off )
Check for other power reset or power off buttons such as an access door compartment safety switch that turns off power to the equipment (found on A/C blower compartment doors)
Turn on "off" switches.
Replace bad fuse. Reset circuit breaker; if necessary replace bad circuit breaker.
Let hot electric motor cool down, then push in its reset button.
Be sure all safety interlock switches such as on compartment doors are depressed and that the doors are securely shut. Replace a bad safety switch.
See
ELECTRICAL POWER SWITCH FOR HEAT
FAN AUTO ON Thermostat Switch
WATER PUMP ELECTRICAL SWITCHES
CIRCUIT BREAKER FAILURE
ELECTRIC PANEL INSPECTION
Blown fuse, tripped breaker Replace fuse or breaker - does the pump run and keep running normally? Be sure proper breaker or fuse size in ampacity is installed - ELECTRIC PANEL INSPECTION Low voltage to the motor Check with VOM at the pressure control switch or at the motor wiring Be sure the proper size of wire is used for the ampacity and length of circuit; Test for low voltage to the building. Loose, improper, or broken motor wire Check wiring against the motor installation manual diagram, check all connections for tightness, shorts, burns, damage Rewire or repair or replace wWhen a sealed compressor motor has "burned out" this means that the internal wiring of the motor has become irreparably damaged: the compressor motor windings may be burned and shorted together or shorted to the steel shell of the motor, or the windings may have burned and simply become "open" or disconnected. If the motor has burned out in either of these ways it needs to be replaced.
Posted on Oct 09, 2012
What is the largest size inverter I can safely use in a 2005 Prowler travel trailer?
ask these guys they seem helpful i did not have enough of your information about the Trailer to continue talking with them
New or Used Travel Trailers
Jun 17, 2016 | RVs
Breaker keeps tripping on generator when I turn on ac in travel trailer
4KW is marginal for HVAC compressor. Breakers get weak with time. Assuming th gen is running properly and the correct voltage is available. A HVAC unit can take 6 times the start current than it takes to run, so it is possible the inrush is too much
Sep 02, 2013 | Makita 9 Hp 4,300 Watt Portable Generator...
I have a 2010 30' cougar travel trailer, we have never used the air conditioner which is a coleman mach model, when I put it on auto and cool it blows cool air but never gets cold am I suposed to
Check the temperature of the air coming out the vent If it's more than 10 degrees below the air going in it's ok. If it's the same temperature, the condensing system may be not working. The compressor may just be a quiet one!
May 18, 2012 | Coleman Mach III Air Conditioner
Instructions for wiring a moving trailer connector
Trailer Wiring Diagrams 4 Way Systems
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
4%20way%20wiring.jpg 4way_vehicle.jpg 4 way tow vehicle side.
4way_trailer.jpg 4 way trailer side.
5 Way Systems
Same as 4 way system listed above but adds a extra blue wire for brake signal or auxiliary power. Used on pop up camper trailers or utility / boat trailers.
5way_vehicle.jpg 5 way tow vehicle side.
5way_trailer.jpg 5 way trailer side.
6 Way System, Rectangle Plug 3/4 inch by 1 inch 6 way rectangle connectors right turn signal (green), left turn signal (yellow), taillight (brown), ground (white). The red and blue wire can be used for brake control or auxiliary. Use on a small motorcycle trailer, snowmobile trailer or utility trailer. Can also be used as custom wiring on trailers with 3 light/wire systems. See "Tow Vehicle Taillight Wiring" below.
6way_rectangle_1.jpg 6 way tow vehicle side.
6way_rectangle_2.jpg 6 way trailer side.
6 Way Systems, Round Plug
Round 1 1/4" diameter metal connector allows 1 or 2 additional wiring and lighting functions such as back up lights, auxiliary 12v power or electric brakes. Note: The black (sometimes red) 12v and blue electric brakes wire may need to be reversed to suit the trailer. Check with a test light or VOM. Uses: horse trailer, travel trailers, landscaping trailer, car trailer, etc.
6way_vehicle.jpg 6 way tow vehicle side.
6way_trailer.jpg 6 way trailer side.
7 Way Systems
Round 2" diameter connector allows additional pin for auxiliary 12 volt power or backup lights. Uses: heavy duty landscaping trailer, car trailer, boat trailers, horse trailer, travel trailer, construction trailer, etc. Check with a test light or VOM.
7way_vehicle.jpg 7 way RV flat blade tow vehicle side.
7way_trailer.jpg 7 way RV flat blade trailer side.
Jan 01, 2011 | 2001 Pontiac Montana
2002 Dodge Ram 1500 A/C Blows Hot When Stopped and Clicking Sound
if the compressor is turning on and and off R1-34 level is low recharge system.
Aug 24, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Dometic Rooftop RV Air Conditioner Logo
35 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
