Question about Pool & Spa
Lay-z-spa is flashing E05 - Pool & Spa
My lay z spa has error code e05
do you have a pentair or sta rite gas heater running your spa?
Apr 04, 2014 | Pool & Spa
E05 code
e05 error code means shorted stack flu switch or sensor. oder heaters have the switch, newer heaters have the sensor. make sure you know which one you have before ordering a replacement.
Apr 01, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Keep getting error code E05 When trying to heat the spa
eo5 is the biggest pain for pentair heaters. it can be caused by several things. stack flue sensor, wiring harness from stack sensor back to circuit board, thermal regulator, flame sensor, etc.......
Nov 30, 2013 | Pool & Spa
Lazy z spa error e05
You can find almost every error code known out there for hot tubs at the following link: Error Codes
Click on that link and then scroll down through them.
Rod
US Parts Center
Aug 26, 2012 | Jacuzzi Pool & Spa
My bestway lay z spa pump and heater unit has stopped working. Three lines flash on the LED panel and all the lights are flashing simultaneously. Non of the buttons work and I have tried re-setting the...
PDF Manual at the link below.
http://www.drinkstuff.com/products/pdf/lay-z-spa-owers-manual.pdf
All lights flashing indicate a fault with the pump.
This is a common fault with these units which the supplier blames on people not following the installation and maintenance instructions.
If you require any further assistance then please just ask.
Aug 01, 2011 | Kitchen Ranges
Pentair mastertemp 200 will work for a while and then stop and give a E05 code. Any Ideas
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. The diagnostic goes further but that is usually the fix. with inactivity, the igniter is always to blame. You really need to fire it off weekly to make it reliable.
Feb 25, 2011 | Pentair Pool & Spa
Pentair Minimax CH Propane Millivolt Ignition Heaters error E05 what is it?
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. The diagnostic goes further but that is usually the fix.. With inactivity, the igniter is always to blame. You really need to fire it off weekly to make it reliable and make sure that your heater is serviced at least one time a year to keep all the internal components operating as designed.
  • PILOT ASSY LP MV CH150 IID
  • Manufacturer: PENTAIR WATER POOL AND SPA INC
  • Manufacturer Part #: 471291
  • Description: Propane pilot assembly for heaters with millivolt ignition.
  • Retail Cost: Approximately $65.00
Dec 08, 2010 | Pentair Minimax Ch 200,000 Btu Propane...
Hot tub heats from 85 to 98, then E05 message. Max setting is 104. It's run for 2 years with no issues getting to 102-104. I have the Pentair manual, troubleshooting chart, but wanted to see if anyone had...
Could be the temp sensor about 50-60 bucks, the book will say the board about 350-500 bucks. Try the temp sensor first. If it's reading over what the water is then that is probally the problem.
Jun 27, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
Code E05
E05 and E06 is the error codes for a faulty stack flue sensor. try changing the sensor first is the cheapest. if that doesn't work check for corrosion on control board in which case will have to change out board.
Apr 20, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
