Question about Rimage Computers & Internet
480i not responding - Rimage Computers & Internet
Trying to hook up a playstation 2 to a sylvania LC195SLX tv
The PlayStation 2 may natively output video resolutions on SDTV and HDTV from 480i to 480p while other games, such as Gran Turismo 4 and Tourist Trophy are known to support upscaled 1080i resolution using any of the following standards: composite video(480i), S-Video(480i), RGB(480i/p,
Which output from the game to the TV are you using?
Apr 13, 2014 | Sylvania Televison & Video
How do we set the picture to 1080 megapixels from 480i?
U can't just do it on ur own setting like 480i to 1080p when ever u want.No,u only get what ever the tv stations modes they set and send out only.Ur tv have the 1080p mode capability mean ur tv can pickup that 1080p mode.Dosen't mean u can change 480i to 1080p by ur self anytime u want,if the tv station is broadcating tv signal to u only in 480i u get only 480i.
Jun 23, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Only showing on 480i even with hdmi cables on my element 55"
Not the problems with a HDMI cable.U getting only 480i because the tv station u are watching are broadcasting tv signal are in 480i only.Tries difference channels like 2 CBS or 4 NBC alway broadcasting in 1080i.See,u will getting 1080i.Ur tv good,it doesn't have any problems.
Mar 14, 2011 | Element Electronics ELDTW401 TV
My TV is only 480i. When my receiver reboots, I cannot see the settings menu to configure the receiver to output to 480i. I need to know the remote keystrokes to press to configure the receiver for...
You did not give your model number of receiver. Some of the ones from 2007 or so have a switch on the back for video resolution, 480i, 480p 720p 1080i so set this switch to 480i.
Mar 08, 2011 | Samsung HDTV Digital Terrestrial Receiver
I need directions....my tv is set on 480i at the moment
The resolution of the TV is set by the source it is being fed with, just like your PC monitor which is set by the PC video card resolution. 480i = 480i display, 720p in = 720p display.
Its your the video source.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 30, 2010 | Televison & Video
Sharp aquos 1080i is showing up at 480i. How do I
I have the same problem I'm sending 1080i to the screen and it will only display 480i. I too would love an answer to this question.
Jul 18, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Adjusting the resolution from 480i to 1080i
Typically TVs will auto adjust to the input signal it receives. If your cable box is only outputting 480i then all the tv will show is 480i. Ensure you have a good 1080i signal going in to the unit and check again
May 04, 2009 | Televison & Video
Want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Dec 18, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Problem with 480i
 This problem has been around for awhile.
 The 2HDW PCB needs to be replaced. Part number 935C966001. It sits on the signal board underneath a metal shield.
 Not a bad repair and remember to unplug the set if you are going to do it yourself.
 Respond to this post if you have any questions and I will reply.
Oct 14, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Computers & Internet Logo
42 people viewed this question
Top Rimage Computers & Internet Experts
David Payne
David Payne
Are you a Rimage Computer and Internet Expert? Answer questions, earn points and help others
