Question about Acer Aspire X3400 PC Desktop
Card reader doesn't work - Acer Aspire X3400 PC Desktop
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
Built-in memory card reader doesn't work
It's a common problem in a OS upgrade. Is your OS 32 or 64bit? Is that the only thing that out of service? In Device Manager do you show ANY Unknown Devices? Is the Card Reader Listed? post results.
Jan 26, 2013 | HP Pavilion g6-2210us Laptop PC
My Acer ASpire 5742 doesn't recognise the card reader
Have you changed your OS? You can find the Card Reader driver here: http://support.acer.com/product/default.aspx?modelId=3277
. Download and install.
Dec 28, 2012 | Acer Aspire Computers & Internet
Have a Magtek card reader and doesn't read Emv cards so how do I fix
those readers will read any card with a mag stripe need to have the programing cards to make it work they can be a pain
Jun 02, 2012 | Magtek MT211 TTL TRACK 1 & 2 Magnetic Card...
Vostro 3500 memory card reader doesn't work
Download and reinstall the card reader driver.
Get onlineand got to www.google.com In the google search box type: "DellSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Card Reader drivers.
May 12, 2012 | Dell Vostro 3500 Laptop Computer (Intel...
Sigma 4in1 card reader not working
Try a different / all other USB ports on the computer, and if possible, a different computer if no USB port on your computer works with it. If it still doesn't see the drive, the drive is probably not working. If it does see the device, but is asking for drivers, provide a disk with drivers that came with the reader - or check the Sigma web site for drivers that work with you OS (Windows, Mac, etc.), download and install / extract.
If it sees the device, but doesn't see the memory card, the reader may not recognize the newer, larger capacity memory cards. SD cards are smaller than 4GB in capacity, and SDHC cards are 4GB and larger. Make sure that if you're trying to read an SDHC card that the reader SPECIFICALLY says it works with SDHC cards. Most SD readers can NOT be upgraded with firmware to be able to read SDHC cards - a new SDHC reader is required.
Jan 30, 2012 | Cameras
The sd card is too small. It doesn't fit into my computer, it came with a little yellow thing to attach to it but it doesn't work on my computer. Help.
Hello akamacho,
It is possible that you have a "MicroSD card". Most card readers can not read micro sd cards because it is too small, so you will need an "adapter" to be the same size as a normal SD card and then you can use it on card readers. I am just assuming (because I can not see it) that the yellow thing you have is the adapter. Make sure the micro SD card is inserted into the adapter properly and make sure that your adapter is inserted properly into your card reader.
If it is still not working, tell me the brand and model of your computer or you card reader. Also indicate any markings you can read from your sd card and the little yellow thing.
You can rate my answer if you appreciate it.
Thanks!
-damneddle
Oct 07, 2011 | Cameras
I can`t transfer files from my pc
use a card reader/adapter and use ur memory card to copy files to ur phone frm ur PC.
or if you have a PC suite.. instal it.. if it doesn work.. then use a card reader.
Jan 04, 2011 | Samsung B3310 Cell Phone
I have toshiba portege r600 and need to get cac card reader for dept of defense. there's express card slot for my laptop. so i shouldn't get pcmcia smart card reader, but express card reader supported by...
It really doesn;t matter which one you choose as long as it works. One is no more "Secure" than the other.
PCMCIA cards are great, So are Express cards. But as said whatever works. Just make sure it has relevent current approved drivers etc. ya be good to go.
Jan 18, 2010 | Toshiba Portege R600-S4201 Notebook
Acer Aspire X3400 PC Desktop Logo
12 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
