Lg j10hd wont start with remote or buttons .protection led on
I have a Sharp tv im trying to program a lg universal remote. I have no codes and can i even do that?
Universal remotes usually have a "Learn" capability.
First you need to figure out how to get into learn mode.
Then you face the Learning Remote IR LED to the current Remote LED. You select the Key or Button one the learning remote that you want to pick up, Then click the similar button on the current remote that is Teaching. The IR signal is picked up by the learner and indicates it has been received correctly.
Then the next key is done
Good Luck
programing rca universal remote YouTube
Dec 02, 2015 | LG Televison & Video
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
Mar 05, 2015 | LG 22LV2500 22" Inch 720p Widescreen LED...
I have all proper 3d equipment, cant get the damn glasses to work, lg led 3d tv, hdmi cables, ps3 as my blu ray player, and ps-100 lg 3d glasses....wont synch with tv and im sooo freakin frustrated!!!!
make sure the left right buttond on remote are set right or it looks like glasses are not working it is the blue button i think, i have the lg 47lx6500 and i had the same thing happen to me.
Feb 12, 2011 | LG Televison & Video
My LG kf750 secret wont start up, wont turn on. It
You could try to hard reset your device, in an attempt to sort your problems out. Be warned that a hard reset will set everything on your phone to their factory defaults, for what you'll loose all the programs you have installed, as well as your personal data. Anyway, to perform a hard reset, turn your phone off completely, by pressing and holding the power button, and, then, answering to the power off prompt. Then, press and hold the Volume Down, the Call, and the Power buttons, until the LED (at the side of the camera) flashes. Release the buttons. That LED should flash in green/red/blue now. When your device powers up, it should be completely cleared.
Hope it works for you, since this is completely theoretical. I have never done it myself.
Regards,
Carlos
May 15, 2010 | LG Secret ? KF750 Cellular Phone
Lg fla screen
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
if remote is OK, then the problem with Remote sensor or related components of the TV.
Dec 23, 2008 | LG 42LC2D 42 in. LCD HDTV
Impossible de sortir le cd audio
try holding down the stop botton down for about 10-15 secs or less it should turn off
Nov 12, 2008 | LG Audio Players & Recorders
Hi i am matt
If the protection LED lights only after the remote voltage is applied (head unit is switched on), the amplifier likely has shorted output transistors. If the protection LED remains lit without remote voltage applied, the amp may have other problems.
Does the protection LED light with no speaker wires connected to the amp and no RCAs plugged into the amp?
Jun 22, 2008 | Car Audio & Video
124 people viewed this question
 Grubhead
Grubhead
