Question about Gateway E-4610d E-4610s Dq965mtg1 Mickelson Trail Motherboard 4001152r 5414
Refencia which is the BIOS for this motherboard
Know how to enter and change the settings the same
I changed the password on my laptop and now i cant remember it can you help me??
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
hope this helps you
Sep 12, 2011 | Computers & Internet
I don't have a password for the set up utility screen!
BIOS password to enter set up?
if no luck with this
Hope this helps you
Sep 07, 2011 | HP Computers & Internet
I don't know my security code
also
hope this helps you
Aug 26, 2011 | Computers & Internet
Codes on how to change a password using php..
im not sure what you mean by php ??
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
The most common way we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 03, 2011 | Computers & Internet
Bios password wont let windows boot up
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 13, 2011 | Toshiba Computers & Internet
Medion Akoya mini 10 netbook 1210 asks for password to enter bios. I want to reset but never known the present password
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased or
When you boot up to the log in screen type in administrator as user if you cant log in During the boot up process you will see on the screen for a short amount of time a certain key to enter set up press and hold that key to enter set up BIOS scroll to set user password or supervisor password you can change or remove the password from there if you are still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable "live" CD which contains software that allows you to change paswords repair/restore/diagnostic almost any computer problem also has a bios reset tool which remove your password and BIOS password although you will have to use a computer with an internet connection you will have to burn it to a disk as an iso then change your firtst boot device to cd During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed the password you must go back and change the first boot device to your hard drive)
Hope this helps
May 21, 2011 | Computers & Internet
My motherboard is Intel D101GGC. On start-up it is showing BIOS ROM CHECKSUM ERROR..DETECTING DRIVE A MEDIA..then a bip sound and then it shows PLEASE ENTER SYSTEM DISK AND PRESS ENTER...i'm not able to...
Go to your bios again set it to default and then restart it.
If nothing happens you need to use your operating system disc to fix that.
Set your first boot sequence to CD first.
Hpe that helps you out!
thanks for using Fixya!
Dec 16, 2010 | Intel D101GGC Motherboard
When i enter BIOS there is no way to set the boot device and just say after exit "install boot media and try again"
you can change a few settings in BIOS but as long as you can remember what changes you have made so if anything goes wrong you can restore bios to original settings
enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
Dec 15, 2010 | Evga H55V (111CDE630TR) Motherboard
PROBLEM WITH BIOS
you need to replace the battery on the motherboard the battery is what saves that info
hope this helped
please rate well
Mar 04, 2009 | ASUS P5S800-VM Motherboard
Gateway E-4610d E-4610s Dq965mtg1 Mickelson Trail Motherboard 4001152r 5414 Logo
29 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
