Question about GE 50-Pint Dehumidifier
Fan does not shut off - GE 50-Pint Dehumidifier
Should the fan shut off when the humidity setting has been reached for model Frigidaire CAD504DWL 50-Pint Two Speed?
Thank you for your post, friend!
I see that your question is if the fan should shut off once it has reached the recommended setting. The fan will run even when the compressor cuts off so that air can pass over the sensor coils to check the humidity. This is a normal operation. I hope this is helpful. -Matt
Sep 12, 2014 | Dehumidifiers
The unit turns on compressor and the fan after awhile the fan turns off and compressor still on.
Sounds like it is a bad fan or bearings. Try shutting off the unit as soon as the fan shuts off and see if the fan turns freely. If not, the fan bearings need lubrication or replacement. If they are not serviceable, you will need to replace the entire fan.
May 19, 2014 | Frigidaire FDF70S Dehumidifier
Why does the fan run non stop? the compressor runs and shuts off but the fan just runs on high and low. I have 3 other dehumidifiers that the fan runs only when the compressor runs...why doesnt the...
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Aug 14, 2011 | Friedrich D50C Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Jun 06, 2011 | Danby Dehumidifier
The cooling fan and will not shut off.
theres a fan/compressor relay inside the case one side operates the fan and the other the compressor,if the fan side contacts weld themselves the relay cannot cycle and the fan will not shut off,remove the wire from the relay to the fan and see if this kills the fan,but dont leave it this way as the compressor needs the fan for air circulation while operating
Feb 26, 2011 | Haier 45-Pint Dehumidifier
Humidifier compressor does not stay on more than 1-2 minutes
Sounds like bad relay on compressor or bad compressor. There is only so far you can go yourself without knowledge in electrical and AC units. Suggest you call a service tech or if you can take it to service cemter near you. Russ
Jul 24, 2009 | Kenmore 5230 Dehumidifier
Just bought a new dehumidifier. does the fan
it should shut off when the compressor is not running. only portable a/c can have fan running constantly
Jul 03, 2009 | Dehumidifiers
Compressor runs, overheats and shuts down..fan does not run...
I have had the same problem. Following the advice of someone on these pages I opened the machine up and checked the fan with a meter. On my model (the 404) it has two settings so two leads; one seemed okay, the other was dead. I checked the circuit where the fan connector plugs in and I got that both speed settings were supplying plenty of juice. Apparently the fan motor is dead. A replacement runs $79 at http://www.appliancefactoryparts.com/. I ordered one; we'll see what happens.
Apr 11, 2009 | Goldstar DH504EL Dehumidifier
Thanks
I went back and rechecked. If the fan mode is selected, you can only set the fan at one of the three speeds. If you leave it in the fan mode, the dehumidifier will not come on.
Once the fan speed is selected, it will run at that speed in the dehumidifier mode. The fan will keep running, even when the dehumidifier (compressor) shuts down.
The only way to get it to turn off is to use the clock setting, which either selects how long it stands-by before starting , or how long it will run before going back to stand-by. DeLonghi calls it "stand-by," we would call it "off." DeLonghi calls unplugged "off."
I've never turned mine to stand-by, because it will never get my entire house down to 30% humidity (I have it where my air handler returns air to the basement). I live in the greater DC Metro area, where 75% humidity is considered extremely dry.
Apparently the normal mode of operation is fan on unless awaiting a clock start, or encountering a clock shut-down; either condition puts it into the "stand-by" mode.
Sep 02, 2008 | DeLonghi DE500 Dehumidifier
DE 500P - Fan will not shut off
If you have the fan icon selected, it is supposed to run continuously. If you use the mode button (not the fan button) to change to relative humidity (the water drop icon), the fan should only run with the dehumidifier.
Feb 19, 2008 | DeLonghi DE500 Dehumidifier
GE 50-Pint Dehumidifier Logo
70 people viewed this question
Top GE Dehumidifiers Experts
J.D. Browning
J.D. Browning
AZBen
AZBen
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
