Question about ASUS Eee PC 1000H Laptop
Router wifi how to make Eee PC 1000H to work as hotspot router it has cable connection and works on win xp home sp3
  • 21 Answers
SOURCE: eee PC 1000H/XP - my wireless connection stopped functioning
1) Try to check your connections. Follow the guide from Microsoft, here: http://support.microsoft.com/kb/314067
2) You could try reseting your TCP/IP stack. Try this:
  1. To open a command prompt, click Start and then click Run. Copy and paste (or type) the following command in the Open box and then press ENTER: cmd
  2. At the command prompt, copy and paste (or type) the following command and then press ENTER: netsh int ip reset c:\resetlog.txtNote If you do not want to specify a directory path for the log file, use the following command: netsh int ip reset resetlog.txt
When you run the reset command, it rewrites two registry keys that are used by TCP/IP. This has the same result as removing and reinstalling the protocol. The reset command rewrites the following two registry keys: SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\
SYSTEM\CurrentControlSet\Services\DHCP\Parameters\
Posted on Mar 19, 2009
Damilare
  • 358 Answers
SOURCE: keyboard for my ASUS Eee PC 1000H is not working
Hello, I'm not actually sure if you can do this by yourself, or you might just have to get a technician to fix it for you.
What I would suggest that you should do is to get a replacement keyboard for the laptop, you can even buy it from an electronics store by yourself and get a technician to fix it for you (If you cant do it by yourself), this way it would be cheaper.
This is because it is not always advisable to try and repair a laptop keyboard, because one way or the other, it would still develpo problem again. So its better you change it outright and put the inconvenience behind you.
Hope this helps.
Posted on Jul 15, 2009
  • 1705 Answers
SOURCE: I am unable to connect my Eee PC 1000H to an
You'll need to us the Fn key functions.
Check out your keyboard, there should be a Fn key, probably on the bottom row. Also, probably in the number row, there's a set of dual function keys, one will have a picture of a screen.
Press the Fn key and the screen function key at the same time, should switch between external and internal screen.
Posted on Jul 21, 2010
  • 30 Answers
SOURCE: just got my EEE PC
Have you put mac access control on your router, if so turn it off? is the router g or n or b compliant and does your pc match? have you set the right security wep/wpa/wpa2? if using wep you may need to not use the passcode but the key 1 which is generated from it.
Posted on Aug 28, 2010
shibuda
  • 1812 Answers
SOURCE: i need webcam driver of
Hello, You can download the webcam drivers from ASUS WEBsite. http://usa.asus.com/index.aspx So please go there website For download copy bellow thelink and paste on address bar. http://support.asus.com/download/download.aspx?SLanguage=en-usSuppose, you need driver for, ASUS K8V-VM
Product =Mother Board So Series = (Socket NO.eg. 754 etc.) So Model= (Model no will be K8v-vm) And please select the O.S (XP / VISTA/ WINDOWS 7) version of the drivers that matches your P.C and search. Now you can download easily one after one.after download all the driver ,unzip the fie with winrar or zip . Download the winrar free, copy the link and paste onaddress bar. http://www.filehippo.com/search?q=winrar Install it . Now right click on every downloaded fileand select EXTRACRT TO THE FILE FOR......,then create a new folder with the withthe driver file, you can install easily. Hope this helps. Let me know if you need more information Thanks
Posted on May 11, 2011
Wifi hotspot
Your question is too vague..
What do you mean you pc won't share connection?
Is it not logging onto the WiFi?
You say you havegood signal; if so then your pc isn't loggiong onto the WiFi..
Nov 24, 2013 | ASUS Computers & Internet
Dell INspiron 7500 laptop
yes of course you are correct, to make this laptop, go onbline wirelss, yoy need to get a wireless router..
Dec 10, 2007 | Dell Inspiron 7000/7500
My dad gave my son an elderly (2001) HP Pavilion xf145 notebook with windows xp. We can't figure out if we need to add a wifi card of some sort, if it can even connect to our wifi or what. It seems to...
You can use either external wifi modem and connect it to the notebook by ethernet cable or (better) use PCMCIA wifi card (second-hand e.g. from eBay?) or wifi usb modem connected direct to usb port. Just check if choosen wifi modem supports your OS WIN XP (and service pack - e.g. WIN XP SP3). In the Reference guide of the notebook is not specified USB version - it seems to be v. 1.0, so it is necessary to get an USB wifi modem compatible with USB 1.0 standard.
Nov 11, 2013 | HP Pavilion xf145 (F3413HR) PC Notebook
I have no supporting CD for my ASUS Eee PC 1000H. How do I down load them to install?
Hello ,
You have to go to the ASUS website write your machine model no then search .
this will give u all the drives of the machine if nothing look for support on the site then click it give your the model no .
download the drivers u can save them on a flash disk then go run them .
good luck
Nov 27, 2010 | ASUS Eee PC 1000HE Netbook
I have broadband thru verizon on my netbook(windows7 OS). can i "jump" off that connection with my home pc, wireless capable, win xp OS? meanoing can i broadcast n\broadband signal so i can surf internet...
Yes, easy way would be through Connectify. It turns almost any Windows 7 OS PC into a virtual wifi router. The software is free. Basically, it will share whatever internet connection your netbook is getting via a virtual wifi hotspot that your other wireless devices can connect to.
http://www.connectify.me/
Sep 27, 2010 | HP Computers & Internet
Hi! do you know how can I make the Fn key work on my Asus eee 1000h laptop? It used to work and now it doesn't :(
Install the drivers
http://www.notebook-driver.com/asus/asus-eee-pc-1000h-netbook-windows-xp-driver-and-utilities/
Feb 07, 2010 | ASUS Eee PC 1000 Notebook
I just bought this eee pc and it not set up like my friend and i like to set it up with win xp
well, you will need a windows XP cd and a valid product code. you will also need either a USB cd rom, or one of those ide to usb kits sold on ebay (make sure it comes with the molex power adapter), and a standard IDE cdrom drive. connect the usb drive to the eee pc and insert the xp disc, restart and boot to the xp disc and install xp that way.
Jun 05, 2009 | ASUS Eee PC 1000H Laptop
I instal new windows and my webcamera is not working.Please give me the link for my PC to downloud. I have Eee PC 1000H
Hi there follow the link bellow and make sure you have installed the chipset drivers and dont rely on the win xp own drivers http://support.asus.com/download/download.aspx Regards Al http://support.asus.com/download/download.aspx
Jun 04, 2009 | ASUS Eee PC 1000 Notebook
Netgear wirleless network and Asus eee 1000H-XP.
Hi try this troubleshooting steps:
Delete the preferred networks of this computer, Check the Internet connection of the Netgear and modem if working properly. Check physically your network connections, make sure that they are connected properly.
Apr 20, 2009 | NetGear DG834G Router
Eee PC 1000H/XP - my wireless connection stopped functioning
Mar 17, 2009 | ASUS Eee PC 1000H Laptop
ASUS Eee PC 1000H Laptop Logo
20 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
