Question about LG WD-80130F 7.2kg Washing machine
Flashing Lights When I select the program all the lights start flashing and nothing happens
2 Suggested Answers
  • 298 Answers
SOURCE: M/N 65130F AS SOON AS TRY
u will need a sevice manual go to appliancerepairplanet.vstore.ca
Posted on Dec 01, 2010
Flashing green indicator lights
When the green light is flashing, it is not at the set temperature. It will be solid when temperature is correct. You are selecting grill or griddle and then turning the temperature knob for that selection? It's not working with either selected?
Dec 31, 2013 | Cuisinart GR-4N Indoor Grill
All the lights are flashing and nothing happening. Powered off and on again. How do I reset the board??
If all the lights are flashing it is without a doubt a faulty main board. If only certain lights are flashing it is showing an error code. Tell me which lights are flashing and will point you in the right direction. Approximately will cost 100 to 140 for a board, which also has to be programmed
Oct 19, 2013 | Bosch Classixx WFO 2866 Front Load Washer
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
Indesit WIXL143 stops part way through program
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Mar 21, 2010 | Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
Kenmore Elite HE3 washer lights light but wash won't start
Sometimes I just have to unplug the machine, wait a few seconds and plug it back in and it works. I guess it resets itself or something.
Feb 26, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Start up Fault
there should be a trouble shooter in the console the blinking lights will tell you what the problem is and the common issues are listed on that paper.
Nov 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
60 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
