Question about JBL MR-4 AM / FM / CD 180 Watts Marine Receiver
Can;t get my unit to work, think I need a new faceplate
Just bought a 2004 jeep cheroke, aftermarket radio, the face plat
the only to recieve a new faceplate, unfortunatly, is to buy a whole other new or used head unit.
Aug 06, 2009 | JVC KD-AVX33 Car Video Player
SRC button on faceplate doesn't work
yup. that can be a reason.
use a new one and check it.
Jul 22, 2008 | Kenwood KDC-225MR 200W Car/Marine SIRIUS...
Pioneer premier deh-p980bt screen went blank
Its the ribbon cable needs replacing going from the deck to the faceplate
May 29, 2009 | Pioneer DEH-P6800MP CD Player
Pioneer deq 7600 display went black today the eq works fine.
the faceplate contacts may need to be cleaned. remove the faceplate, and using an eraser, clean the metal tabs on the main unit and rear of the faceplate.
If this doesnt remedy the problem, service is required. May be the light unit in the faceplate.
Dec 22, 2008 | Car Audio & Video
Faceplate not working - will remote solve problem?
PLEASE FIRST CHECK THE FACEPLATE TO HEAD UNIT CONNECTIONS (WHERE THE FACEPLATE CONTACTS THE HEAD UNIT ).
THEN IF U ARE SATISFIED ,REPLACE THE ENTIRE RECEIVER.
May 10, 2008 | Pioneer DEH-P4700MP CD/MP3/WMA/WAV...
Kenwood KRC -X858 Faceplate/Power Problem
I have the exact same problem. I called the tech line and the tech reported that the ribbon cable is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Apr 26, 2008 | Kenwood KRC-X858 Cassette Player
Faceplate DEH-P5500MP
dude im real good at this stuff and if u dropped it once ur lucky it still worked but if it dont work now ur definitely going to need a new one...
Jan 09, 2008 | Pioneer DEH-P5500MP CD Player
VR500CSBT Reseting itself when I remove the faceplate
no man, you should take a direct line from the car battery to the unit, then you radio station will be saved all the time, do it in specialist in cars, just tell it that
Dec 04, 2007 | Roadmaster (VR500CSBT)
Display is OUT but everything functions....... what to do?
The problem is not the faceplate for any of you, it is inside the main unit. If you know how to solder, you can fix is very easy. First take the top off the unit, there is 1 screw in the back middle. Then take the CD player out. It has 2 screws holding it in at the front corners at the bottom of the CD deck. Use a number 2 phillips and take out the gold screws holding the CD deck in place. Then you can pull out the CD deck, and be careful not to damage the ribbon cable connected from the CD deck to the main board. The deck can just sit up and over to the left to get it out of the way for what needs to be soldered.
Look inside the main unit on the board and you will see in the front right corner a series of surface mount resistors all connected in series. Just reflow that solder on them with a small amount of new solder added and the display will once again work perfectly. That solder is very heat stressed, that is the problem. I have fixed dozens of these over the last few years. Make sure you put it back together the same as it came apart, and you are done.
Nov 28, 2007 | Kenwood KDC-X590 CD Player
Stolen faceplate
mine was stolen too. I thin you need to contact the seller or manufacturer to find out. If it is the same model number as it is on the main cd player part then I think it can work. But suggest you to contact the manufacturer.
Aug 08, 2007 | Jensen MP5720XM
Car Audio & Video Logo
37 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
isaac johny
isaac johny
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
