Question about Marantz Audio Players & Recorders
Loud distorted noise from the output
Only on one side, sometimes loud hiss kinda sound sometimes really loud almost thunder like. Cables in good condition, source in good condition. If i only touch the amp it's enough to give a good noise. And when i turn it on it starts slowly building up. like there is something not getting warm? after a while it sounds ok but don't touch the amp. It's an old pm8000, have it for years now.
  • 40 Answers
Well it sounds like a solder pin is getting lose. does it happen when you rattle the vol knob gently? Maybe the potentiometer does also have to be cleaned
Posted on Nov 25, 2014
SOURCE: Losing sound, hearing scratchy noise from the speakers
My yamaha tuner does this every few months. POwering down the receiver and rapidly turning it to full volume then no volume a dozen times clears the contacts on the volume potentiometer. The problem always goes away for another couple of months.
Posted on Apr 27, 2007
robotek
  • 1512 Answers
SOURCE: sony TA-540E TWIN DRIVE AMPLIFIER
Hi Jimbob. Sounds like you have dirty/dry controls/switches. The contact lubricant dries out on them producing intermittent and scratchiness when you operate them. Clean any offending controls or signal switches with CRC2-26 by squirting(to flood then internals) each control/switch. you will have to do this from the inside of the amp. You may also have a dirty speaker protection relay, sound may return to a dead channel when you turn the vol up points to that. Good Luck. If you need more info feel free to get back to me here. Happy to talk you through more if you cant sort it out.
regards
Graeme
Posted on Mar 22, 2008
robotek
  • 1512 Answers
SOURCE: Technics SUV4X new class A Amp - 20 odd years old but lovely sound !!
Hi guys
Quick check... If the amp still stays in safety mode with the vol turned down and the speakers disconnected, it will have failed in some way. Since you have the safety operation light ON, you can expect that the power transformer is OK. I would expect that you have a DC offset condition on one channel. The most common problems you may have are
  1. dry solder joints about the power stages such as regulators, and output/driver transistors/IC's.
  2. blown output transistors/output IC with possible fusible resistor failures, and or sometimes burnt up printed circuit tracks.
  3. a voltage rail failure from a burnt fusible or power supply component.
If you are up with electronic fault finding, soldering and have the tools, have a go yourself, I could talk you through it. If not, I would suggest you contact you local HiFi specialist and find who can repair it or at least check to see what has failed for you. Good Luck. If you cannot find someone, hit me back and I will try to find someone for you. Cheers
regards
robotek
Posted on Sep 06, 2008
  • 130 Answers
SOURCE: Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Posted on Dec 05, 2010
richroth
  • 9472 Answers
SOURCE: BACKGROUND I have a NAD 306
While capacitors may last decades on a circuit board, they're subject to age, manufacturing defects and damage from voltage spikes. Sometimes a bad capacitor will give visual clues you can spot with a careful look. If it appears to be good, you must still test it both in and out of the circuit. A defective or damaged capacitor will reveal itself when you check it with an oscilloscope or multimeter
Examine the capacitors on the circuit board. Normally, they should have a smooth, symmetric shape. If you notice cracking, bulging or dark streaks on the capacitor.
Examine the circuit schematic to find the power supply paths. Connect the oscilloscope to the circuit board's DC power by first connecting the grounding clip to power supply ground, then hooking the probe onto a point that has positive or negative DC power. Set the oscilloscope to DC coupling. If the oscilloscope shows excessive AC ripple or reads a below-normal DC voltage, an electrolytic filter capacitor probably needs replacing.
Disconnect all power from the circuit board. If the power has been on, give the capacitors a few minutes to discharge.
Posted on Jan 29, 2011
My digital effects does not work at all. It makes a noise only on the distortion setting and all it does then is hiss. Any ideas
Make sure your power supply is doing its job. check output reading w/ a ohm meter and compare it to the info on the back of the supply. i am assuming your using tje recommended power supply. if this does not prove to be the cause. you may have send it out for diagnostics and most times it's just cheaper to buy new. good luck
Sep 15, 2014 | Music
Recently ntly bought a new processor fx 6300 AMD
Could be a cable routing problem; interfering with other cables . Try re routing/separating the loom.
Oct 27, 2013 | AMD FX Six-Core Processor Model FX-6300...
I have had this loud hissing in my left ear for about 3 weeks
We do not hand out medical advice here. Try WEBMD.com
Nov 02, 2012 | Cars & Trucks
There is a white noise hiss after every sound that comes through the headphones.The sound decays over approx 1.5 seconds. Have tried moving the base around the room, spent $$$ on high quality connection...
Maybe changing channels will do the trick. The noise your hearing is like a distortion of frequency from a nearby device that is using the same frequency the headphones uses.
Oct 13, 2010 | Sony MDR-RF970RK Headphones
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Subwoofer problem
The distortion you are experiencing could be due to a few things,
Drivers for the device,ie the latest updates applied recently,
This may affect the performance of the units functionality.
The cables not being connected properly,poor signals and connections,
The source from where you original sound signals came from,
ie,over recorded source,too loud for the system speakers to reproduce the correct tones,
this is dangerous to speakers and the listerners hearing comfort too,
The simplist way to check your speakers are ok is to check them on another system with a similar sound device,or plug a set of head phones into you creative 4.1 output on a low volume,
is there a signal output to your head phones???
The most comon form of distortion is the equaliser setting on the original source output,turn it down to help eliminate the frequency your looking for and the adjust EQ to suit your comfort zone.
Apart from this will be unplug each zone and test individually,
should be a quick and painless solution,
Microphone feedback can damage speakers too,,,,,,
If the distortion remains try different speakers on the output.
Hope this helps , MISTERDJ
Aug 25, 2009 | Audio Players & Recorders
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Sound Distortion
somekind of hardware side failure or bad drivers.
I hear sounds from my audio output if i connect my headphones there directly but when I connect it to my speaker system they filter the distortion.
Apr 13, 2008 | ASUS M2N-E SLi Motherboard
DISTORTION
1) if you are using the PC sound card to record this is where your hiss is coming from. you need to get a recording card that has low noise or some other recording USB input device to get CD quality recordings
OR
2) if you have to use your PC sound card check your PC volume level for line in, don't let it get high or it will distort. you will have to experiment with the MD4 levels and PC sound card level to find a good middle ground with low hiss and no distortion
and a singer that sings away from the mic to reduce distortion.
hope this helps
thanks for your rating
Jan 09, 2008 | Shure SM87 Professional Microphone
Hissing sound from inside.
what kind of a hiss and from which side of the laptop? ... u can put your ear next to the unit to attempt to hear the hiss better ...
Nov 03, 2007 | HP Pavilion zd8000 Notebook
82 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
