Question about Staples SPL240 Calculator
Will not reset to 0 - Staples SPL240 Calculator
How do you unlock a TSA COMBINATION LOCK WITH fogotten. number?
The only way to reset a TSA Combination lock is to turn the numbers until you get it. The good news is that you only have 1000 possible combinations. Start at 0 0 0, then 0 0 1, 0 0 2, etc...
There are posted videos on YouTube that talk about how to reset locks with unknown combinations but they are specific to the brand of the lock; assuming they aren't fake videos anyhow.
Nov 19, 2013 | Home Security
I had the problem of the full ink absorber. I already washed and cleaned all the parts related. Now, I need to reset the counter; how I can do it??
<Ink absorber counter resetting>
Reset the ink absorber counter (to 0%) when the ink absorber is replaced, or after the logic board is
replaced.
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting
mode.
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s)
according to the kind of ink absorber whose value should be reset to 0%.
(13/32)
Time(s) *1 Ink absorber
0 times Main ink absorber (0%)
1 time Platen ink absorber (0%)
2 times Both the main and platen ink absorbers (0%)
3 times or more Press the ON/OFF button to return to the ink amount resetting mode.
3) Press the ON/OFF button to specify the ink absorber whose value should be reset to 0%.
4) After the ink absorber counter is reset, the counter value is printed automatically.
("D=000.0 Ps=000.0" is printed at the top left of the paper.)
*1: According to the number of times the Stop/Reset button is pressed, the LED lights as follows:
- Odd number of times: Alarm LED lights
- Even number of times: ON/OFF LED lights
Nov 01, 2013 | Canon PIXMA MX310 All-In-One Printer
I get a code c3451
C 3451 and C 3452 Fusing warm up malfuntion.Verify the fuser unit and clean the thermistors and the thermofuses and try reset the error code.For reset press following keys:
Utility - Meter count - Details - Stop - 0- Stop - 0 - 1
introduction 0-0-0-0-0-0-0-0 press enter and select the trouble reset(counter windows).
Feb 14, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
I have made a folder to store some messages in my phone and now i have forgotten the password to unlock it. What should I do?
Hi!Did you change the default password of your phone?If not,try to enter or type the default password (0000) or (000000) to unlock your folder.If ever the default password is not working,you may try this other secret codes for motorola.
Motorola
c350 english languge
menu
setting
1 1 5 2 6
(T190, T191, T205) master code
- 19980722
- 20010903
P2K test menu:
*#06#, menu, menu, 048263*
Test comands:
32*116*1*0*0 - read phone code
32*118*1*0*0 - read security code
18*0 - factory reset, phone code off
18*1 - master reset
54*18*1 - full phone reset
10*0*6 - select 900/1800
32*279*1*0*8 - model
32*383*1*0*0 - flex version
Hard reset MPX200, MPX220 - blue button + power on
Feb 25, 2011 | Motorola Mobility ROKR E6 Smartphone
Hi, My sgh-f488 dual SIM i forget my password i wont to reset it fahmyuthman@yahoo.com
Samsung IMEI number: * # 0 6 # Software version: * # 9 9 9 9 # albo * # 0 8 3 7 # Net Monitor: * # 0 3 2 4 # Chaning LCD contrast: * # 0 5 2 3 # Memory info: * # 0 3 7 7 # albo * # 0 2 4 6 # Reset memory (SIMLOCK`a removing!!!): * 2 7 6 7 * 3 8 5 5 # Reset CUSTOM memory: * 2 7 6 7 * 2 8 7 8 # Battery state: * # 9 9 9 8 * 2 2 8 # Alarm beeper: * # 9 9 9 8 * 2 8 9 # Vibra test: * # 9 9 9 8 * 8 4
defult code 00000000
May 08, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Out of fuser web.I need to reset it on nwm.How I can do it ? Please help Mashine is xerox 5790
1.start +0
2.6789
3.dc135 hsfi line 20 clear
4.nwm accsess
6.read write
7.reset 3984 to 0,
8.reset 3985 to 0,
9.reset 3986 to 0,
10.reset 3987 to 0
Then open mashine door,take out fuser web sensor and put it back.
Message out of fuser is gone.Now it is ready to make copies.
Apr 12, 2010 | Xerox DocuColor 12 Printer
I want to reset setting my sgh-p520 but i forget code
Try this:
IMEI number: * # 0 6 # Software version: * # 9 9 9 9 # albo * # 0 8 3 7 # Net Monitor: * # 0 3 2 4 # Chaning LCD contrast: * # 0 5 2 3 # Memory info: * # 0 3 7 7 # albo * # 0 2 4 6 # Reset memory (SIMLOCK`a removing!!!): * 2 7 6 7 * 3 8 5 5 # Reset CUSTOM memory: * 2 7 6 7 * 2 8 7 8 # Battery state: * # 9 9 9 8 * 2 2 8 # Alarm beeper: * # 9 9 9 8 * 2 8 9 # Vibra test: * # 9 9 9 8 * 8 4 2 #
Let me know if this works.
Oct 06, 2009 | Giorgio Armani Samsung P520 Cellular Phone
Eurovox
Use the remote and:
Menu>Config>DeleteData>DeleteChannels>OK>OK (pin = 0 0 0 0)
It will say please wait for channel delete
Use the remote and:
Menu>Config>DeleteData>Factory Default>OK>OK (pin = 0 0 0 0)
It will say please wait for factory reset and after 10seconds you will be returned to the scanning screen.
Sep 03, 2009 | StarTech.com StarView SV211K 2-port KVM...
Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
What is the master reset for a v6 razr???
go to main menu then settings. click initial set up scroll it there you will see master reset. click master reset you will see enter security code type 000000 then enter it will reset itself wait it will shut down by itself and activate again
Jun 24, 2007 | Motorola Mobility MOTORAZR maxx V6...
Staples SPL240 Calculator Logo
13 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
