Question about Makita Factory-Reconditioned 2.5 HP Air Compressor MAC2400
Air compressor pressure not regulating
I have a Makita MAC 2400 twin stack air compressor. I don't seem to have a manual but the regulator does not regulate. The compressor does cut out at around 125 psi but I don't seem to be able to adjust the cut out pressure. I loaned it out and it was this way when it returned. As far as I know, it was working fine when I loaned it out,
  • 285 Answers
Usually you cannot adjust the cut out pressure of the tank/motor itself, this is why they have regulators, which regulates the pressure flowing down the air lines (regulators like these dont regulate actual tank pressure cutout). To regulate air flow using the regulator knob, you actually have to have air flowing through the hose while you make the regulator/pressure adjustments as regulators regulate pressure DOWNSTREAM from the actual regulator itself.. so air flowing through is a must. Attach an air blower or something similar and let air start flowing through the hose. Now turn your regulator knob in the "-" direction to decrease regulated pressure. It is best to bring pressure all the way down to "0" first, then open the regulator up (by turning to the "+" side) and pressure will rise until you get to the desired pressure needed for the air tool in use. The tank pressure will still be between 80-125 PSI as the motor regulates and keeps the pressure in the tank between these values automatically, but your line/hose air flow pressure will remain at the regulated pressure (say 40 PSI or whatever you set using the regulator knob).
Hope that helps and makes sense.
Please rate this solution on FixYa!
Posted on Jun 20, 2009
Where can I buy a Makita Mac2400 air compressor regulator
Makita parts are available at WWW.toolpartsdirect.com A small universal regulator may also work if the fittings match-up. When using a universal regulator make sure that the regulator fits thru the hole in the panel or just adjust the hole size. Universal regulator costs about 20 dollars. Good luck
Mar 03, 2015 | Makita & Sealed Mac2400 Big Bore 2.5 Hp...
My makita model 5200 air compressor regulator will not adjust pressure--replaced with a new one-- no change.help!!
you would need a separate regulator to regulate outgoing pressure and you have only an on/off reguastor.
Oct 14, 2014 | Air Tools & Compressors
Blew off regulator knob
Parts can be ordered form www.toolpartsdirect.com. Air regulator should be adjusted with very little air pressure in the system. If you are adjusting the regulator with full tank pressure, you are overworking the plastic parts within. Over time, water will rust parts inside of the regulator. I would order the complete regulator. You could also remove the regulator part of the manafold and use full pressure to the quick connects. If you need to regulate the air pressure down a bit, purchase a universal regulator and install quick connect fittings. Male fitting to air in and female fitting to discharge port. Install this regulator to one of the quick connect fitting on the a/c. Good luck
Dec 23, 2013 | Hitachi EC119SA Twin-Stack Air Compressor...
The regulator is leaking air and will not support the air tool I am using
They do not show the regulator as serviceable. It looks like you have to buy a complete new regulator. It is part #410028-E. You can find it on this link reference #42.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/MAC2400
Jul 13, 2011 | Makita Mac2400 212 Hp 42gallon Twin Air...
Makita MAC2400 2.5 hp compressor has started leaking from the regulator. Is there a repair for this? Thanks
Replace the regulator, you can get a new one from the home depot or just about any good hardware store.
May 02, 2011 | Makita Mac2400 212 Hp 42gallon Twin Air...
I changed the regulator twice and the compressor still does not stop at the psi where i want it.
The pressure regulator adjusts the line pressure! The pressure switch is what turns the pump on and off. If you are trying to maintain a line pressure with the switch and not the regulator,,, you are never going to accomplish that. I would have to guess that your compressor normally run's between 95~125 psi on the "switch" so if you adjust your pressure regulator to 110psi it will maintain that till the tank pressure drops below that point. then it will drop as low as 95 until the pump restarts again. If you are trying to get the switch to run up higher than that,, "stop now" as you will only burn the thing up by trying to go higher that it was designed to run at from the factory!
Jan 10, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Need a new pressure regulator for my ec119sa. Where can we get one. Thanks
Here is a link for an online supplier who sells parts for those
http://www.mastertoolrepair.com/ec119sa-p-7715.html
The regulator is marked as a "pressure reducer" (0030) and is $44.80 on that site. Good luck.
Dec 08, 2009 | Hitachi EC119SA Twin-Stack Air Compressor...
Pressure regulator control knob leeks air and will not allow unit to reach cappacity
I assume turning up the pressure doesn't help. The regulator probably has a torn diaphragm. It will need replaced (i doubt you can get a rebuild kit).
Oct 14, 2009 | Hitachi EC119SA Twin-Stack Air Compressor...
What the prop
This is caused by a bad pressure regulator most likley, or you might check the drain on the bottom to ensure it is closed.
Thanks
Zerko
Aug 30, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Makita Factory-Reconditioned  2.5 HP Air Compressor MAC2400 Logo
885 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
Billy Mac
Craig Butler
Craig Butler
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
