Question about Nikon 1 J1 Digital Camera
Lens error. Reattach the lens. - Nikon 1 J1 Digital Camera
3 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: Lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Apr 14, 2010
  • 1170 Answers
SOURCE: Nikon S220. Lens error. turns on but displays lens
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 31, 2010
Tokina canon eos 350D error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 350d service manual link:
http://goo.gl/ELh523
it will help you to save a lot of money
Hope it helps, Thanks
Apr 08, 2013 | Tokina AT-X 124 PRO DX Lens for Canon
F-- error code
May I assume you're asking about a Nikon camera and not about a printer or copier?
This indicates that the camera is not communicating with the lens. This happens with older lenses that do not have the electronics to communicate with the camera. It can also indicate that the lens is not making proper contact with the camera. In this case, remove the lens, clean the contacts (both on the back of the lens and in the mount on the body, and reattach the lens. Gently wiggle the lens to make sure it's making proper contact.
Since you didn't name the "newer" lens I can't tell you which of the two cases apply.
There is a third possibility: that the lens is faulty. If you can get access to another camera body, try the lens on it.
Feb 11, 2013 | Office Equipment & Supplies
No image was shown on screen while i still can take photo.
According to ehow:
Turn off your Canon 1000D and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • Place the body cap on your camera to keep dust out. Attach the front and back lens caps on your lens to prevent scratches and other damage.
  • Let the camera sit for 20 minutes. This will clear the camera's memory.
  • Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
  • Press the shutter release button (the button you push to take a picture). If you are still receiving an Error 99, the problem is most likely caused by the camera body itself. The camera body must be serviced by a professional camera technician.
  • Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • Turn off the camera and reattach the lens. Turn on the camera and press the shutter release button. If you receive an Error 99, turn the camera off and remove the lens.
  • Turn the camera so that it is face down, and gently clean the lens contacts on the camera body with a number 2 pencil eraser or soft cloth. The lens contacts are the eight small, gold pieces on the bottom of the lens mount. Be careful not to let any of the eraser scraps fall into the camera body.
  • Turn the lens so that the side that attaches to the camera is upside down. Use the eraser or soft cloth to clean the lens contacts on the lens, being careful not to let any eraser scraps fall into the lens.
  • Reattach the lens to the camera. Turn on the camera and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the lens. Take the lens to a professional camera technician for repair.
  • May 11, 2011 | Panasonic Lumix DMC-FS4 Digital Camera
    Every time I turn on the camera it sais Error 99 could anyone explain it to me .thanks chris
    According to ehow:
    Turn off your camera and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • 6 Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • May 11, 2011 | Cameras
    Nikon 18-55 f:3.5/5.6Camera error: no lens fitted or non-CPU lens
    Remove lens, clean contacts, reattach lens, wiggle it some to seat contacts.
    Dec 18, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
    Lens error
    Remove the lens, clean the contacts, reattach the lens, and jiggle the lens to seat the contacts.
    Oct 24, 2009 | Nikon Coolpix S210 Digital Camera
    An error FEE Flashing comes when the camera is turned on
    What lens?
    If it's a CPU lens, remove the lens, clean the contacts, reattach the lens, and jiggle the lens to seat the contacts.
    If it's not a CPU lens, you'll have to use it in the Manual (M) mode.
    Oct 04, 2009 | Nikon F60 35mm SLR Camera
    Same thing happened to me!!!
    1)Remove the lens from the camera. Put the body cap on the camera, and put the rear lens cap on the back of the lens. Make sure you are in a clean environment.
    2)Take the rear cap off the lens and use the blower to blow large pieces of dust off the lens. Go around the entire rear part of the lens with the blower.
    3)Dip the swab in the isopropyl alcohol or cleaning solution. You should use only a light amount; the best way to ensure this is to wear light vinyl gloves, like those used by health care providers, and squeeze the swab with your fingers after dipping it in the solution. Gently clean the contacts on the lens with the swab. After you have done so, use the blower on the lens contacts again.
    4)Repeat the procedure on the contacts on the camera body.
    5)Reattach the lens to the camera and test it to see if the error or focusing problems still exist. If they do, try cleaning the contacts again.
    Sep 01, 2009 | Nikon Coolpix S210 Digital Camera
    Lens error with my Nikon D40 camera
    Remove lens, clean contacts, reattach lens. Now give it a little wiggle to seat the contacts. Does that help?
    Jul 16, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
    Nikon D80 error msg "F--" and "r02"
    Remove the lens, clean the contacts, reattach the lens, and jiggle the lens to seat the contacts. If that doesn't fix it, either the camera or the lens may require service.
    Feb 19, 2009 | Nikon D80 Digital Camera with 18-135mm...
    Nikon 1 J1 Digital Camera Logo
    23 people viewed this question
    Top Nikon Cameras Experts
    Ric Donato
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
