Question about Zanussi Washing Machines
Excessive shaking, been told to contact Harold Evans.
Excessive shaking and not fit for purpose.
What exactly is the deal with Shepherd Book?
Although it was never explained on the show or in the movie, the story of Shepherd Book's past was eventually told in a graphic novel called Serenity : The Shepheard's Tale. After running away from home and his abusive father, the young Henry Evans fell into a life of crime, and was then recruited into the Independence movement. As tensions between the Independents and the ruling Alliance increased, Evans volunteered to infiltrate the Alliance military and spy on them using a video transmitter implanted in his eye. After killing a man named Derrial Book and stealing his identiy, Evans joined a law enforcement agency, from where his ambition and drive attracted the attention of the military. When war broke out, Evans/Book attempted to orchestrate a simultaneous six-planet strike to end the war "in one day", but instead presided over a massacre of Alliance forces, including the loss of the starship IAV Alexander and the 4,000 aboard. Book was then discharged and dumped on a nearby planet via escape pod. Several years later, Book woke up in a homeless shelter after being beaten by Alliance soldiers for his role in the Alexander disaster, and had a spiritual revelation while eating a bowl of soup, which prompted him to join the church and train as a Shepherd. Ten years later, he left the church as a missionary, and took passage on the transport Serenity (as seen in the episode of the same name).
Sep 04, 2016 | Firefly (2002)
I've got the 1850 Pulse which I can't get it to run. I've cleaned the carb 4 or 5 times, and cleared holes and jets with a fine wire. New gas in tank, plenty of gas flow to carb. I can start with gas...
Harold, it sounds like fuel based issue, have you checked the screen on the fuel tank? this should be a gravity feed, and not pumped fuel...Try an external fuel supply, for testing purposes....
Mar 02, 2011 | Coleman 1850 Watts Generator Each...
James Street's son, Harold, is 10 years old today. Harold, a studious young fellow, already is making plans to go to college on his eighteenth birthday, and his father wants to start putting money away now...
James Street will have to deposit $5910 dollars each year, for eight years, into that "planning" account. Compounded annually, it will be just enough to cover the four amounts to be withdrawn from the account on years 7($18,000), 8($19,000), 9($20,000) and 10($21,000) of the account. Comes down to about $9 left in the account upon the last withdrawal.
Jan 26, 2011 | Computers & Internet
What is the purpose of the removeable pan under the refrigerator, do I have to empty it regularlary, as it is fitted behind a difficult to remove front vent plate and skirting board. I have only just...
They tray is for in case the freezer builds up to much frost and you need to unplug it to defrost it. There is a tube that runs down to the tray where the water drains into. After defrosting you can dump the tray when it accumulates water.
Dec 03, 2010 | Baumatic BR15A Compact Refrigerator
Viking VDSC3656 oven relay (PM010129) failed again
Try to find a relay that has higher contact ratings. Grainger hardware might have one that would fit. It sounds like a design problem and requires a bit of re-engineering to fix it permanently!
Sep 09, 2009 | Viking DEDO205 Stainless Steel Electric...
I have just bought a brand new Maytag american fridge freezer but when my plumber fitted it he noticed the door on the freezer side doesnt shut properly and there is a gap all around the door. I contacted...
under sale of goods act, appliance has to be fit for the purpose. exchange of a faulty new appliance is not automatic but repair has to be carried out within a reasonable time and the normal ruling of a reasonable time is 1 month.
demand a replacement from the retailer. if no joy, it is very easy to issue a writ under the small claims proceedure - you don't need a lawyer for this.
go for it
Dec 02, 2008 | Maytag Refrigerators
RCA DLP television lamp problems
yhere is no reason to shake the tube...either they are good or bad and it sounds like what you are dealing with is a bad tube
Sep 20, 2008 | Televison & Video
Excessive shaking when braking or at speeds above 20mph
Yes it is possible. The drivetrain spans from the transmission down to the differential. Anything out of the ordinary could and would cause shaking. First to be checked are the universal joints, then the U-joint straps (there would be several), mounting brackets, pinion yoke and its support. Normally, everything should be tight with nothing that can be budge or moved when you yank at them.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | 2005 Jeep Liberty
Washing Machines Logo
16 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
