Question about Remington Mulchinator Electric Blower Vacuum - 350 CFM, Model RM1300
Need a replacement bag for RM 1300 Mulchinator
The zipper broke on the bag
Oreck bag zipper is stuck and can't open bag
No fix. You can order a replacement bag from your local oreck dealer.
Jan 01, 2017 | Oreck Vacuums
HOW DO YOU PUT THE BAGS IN THE EUREKA POWERMITE
My guess is to wear thick work gloves unhook metal cord from neck, unzip zipper and install or replace bag and put everything back.
Jul 14, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Having a terrible time keeping the bag attached during use. I am tired of cleaning the inside of the cloth zippered bag. I am using the correct Oreck vaccum bags, and using the metal clip that holds the...
I would Recommend getting a docking system. its $20 and takes place of the metal clip and ensures that the paper bag and outer bag both stay in place and to ensure no leakage.
Sep 04, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I need vacuum cleaner bags for a WST 1300
call a vacumn or small appliance repair shop most vacumn repair shops will know what bags you need esp if they service your model or may be able to tell you who to call
Dec 18, 2009 | Vacuums
I broke the zipper on the cloth bag on my kirby gen. 3 can i replace this myself
Yes.
To order Kirby vacuum bags, replacement parts, or cleaning products, please visit your local independent Kirby Distributor, or call:”
1-800-437-7170 United States and Canada
Nov 15, 2009 | Kirby Generation 3 Bagged Upright Vacuum
How do you replace the bag on a Hoover Elite 200?
I had the same problem and just figured it out myself. Detach the clamp (attamched to the bag) from the handle. Then slide the bag out from the clamp either left or right. The cloth bag then opnes and you can replace the actual bag inside. Hope this helps.
Nov 11, 2009 | Vacuums
It stopped sucking but the brush still spins.
Hi! You have most likely, A blockage. Open up your zipper, take the paper bag out. Inspect the opening where you bag attaches. Do you see debris? If you do, try pulling it out. Now, you might want to do this next step outside, or in the doorway, or garage. With the nozzle facing away from you, turn on the machine, you still have the bag out, and the zipper undone, this will tell you if the clog is further down. Air should burst out of the opening. Be careful, because debris could also burst out. If this is the case, then you shoul;d be able to replace your bag, and zip it up and get to vacuuming. If not, then you need to unhook the bag from th front bottom of the cleaner and uhnhook the wand. It either turns counter-clockwise, or has a rubber covered release button. Here you should be able to see further blockage. Somtimes you can reach the blockage from the bottom of the cleaner where the opening is in the nozzle. Do all of this with the cleaner unplugged for safety. With these steps, you should be able to free the clog and get back to vacuuming. Oreck is nice because without all the bells and whistles it is a pretty easy machine to keep maintainanced. Remember to have your vacuum checked out at least once a year by a qualified vacuum doctor. Hope this helps. Thanks, Rene (The Vacuum Doctor)
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The dust bag inside the outer zippered bag keeps coming loose and making a HUGE mess. does it lock down or something? Wife is ready to throw the whole thing away.
Hi
On most types there is a bayonet type fixing - 2 lugs that line up with 2 slots in the bag seal plate.
You usually need to rotate the bag 45 degrees to push the lugs into the bags plate, then rotate it so the bag is upright again.
This locks it in position.
When you have it working - clean the outer bag outside, as it will continue to throw dust out unless clean.
Sep 07, 2009 | Vacuums
Vaccum Bag
Slide the plastic piece off the cloth bag and open the top. Looking down into the cloth bag, you will see the old bag. It is secured to the machine near the top. You will find the cardboard collar about a third of the way down. Remove it carefull. Now, stand BEHIND the machine and put your knee against the back of the handle and taking the new bag, open the hole in the cardboard collar and insert the bag into the cloth bag and put the cardboard collar onto the handle fitting. It helps to put the lower part of the hole on first and then press the top of the collar onto the handle fitting. The idea of standing behind with your knee against the handle is so that as you attach the bag, you will be pushing against your knee which will steady the machine and allow you to use the required force to complete the action. Once completed, fold the top of the paper bag down, so that when you replace the top slider, the paper bag is NOT clamped between the cloth bag and the slider.
Jan 25, 2008 | Hoover Soft Light U4266-940 Bagged Upright...
Remington Mulchinator Electric Blower Vacuum - 350 CFM, Model RM1300 Logo
37 people viewed this question
Top Remington Vacuums Experts
JoeVacs
Are you a Remington Vacuum Expert? Answer questions, earn points and help others
