Question about Echo Blower Nozzle Es 2400 Pb 200 201 2100 21001420561
Echo blower bogs down
Runs good for a while, then not so much
  • 246 Answers
SOURCE: Echo PB413H running rough
Hello:
From your Description it Sounds like the Exhaust is Restricted or the "H" Mixture Screw Resuires Adjusting.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
SOURCE: Echo PB-413H bogs down
Echo tools have a screen in the muffler to arrest sparks. Take off the muffler and remove this screen
Posted on Aug 12, 2009
  • 148 Answers
SOURCE: Echo leaf blower is bogging down at full throttle,
Have you tried cleaning the carb?
Posted on Aug 24, 2009
Testimonial: "Thanks for the suggestion, that sounds like what it may be. "
  • 7 Answers
SOURCE: Echo ES210 handheld blower. Just stopped running.
replace fuel ines and bushing , comes apart inside gas tank
Posted on Sep 11, 2009
SOURCE: echo gas leaf blower bog down
Likely dirt in high speed needle valve(H); could be leaky fuel line(air leaking in), plugged fuel filter, pinched fuel line, etc - anything restricting flow of fuel. Likely, you aggravated an existing problem by cleaning the air filter which would have been providing some choke effect if it were partially plugged.
Posted on Sep 24, 2009
How do i adjust the carb on an echo blower
Not sure what carb you have..You should be able to see a spring loaded air/gas adjustment screw on the carb..once running turn clockwise until motor starts bogging down then the other way until it does the same..keep adjusting back and forth unti it runs smooth..
you may have another on the bottom of the carb bowel..do the same with it...if this doesn't work needs a rebuild kit..good luck..
Sep 27, 2014 | Echo Pb-403T Leaf Blowers
Echo hedger bogs down after running for a few minutes
Keep a can of WD 40 handy, spray the workings regularly. Shrubbery is sticky.
Nov 26, 2013 | ECHO, Inc. 20 In. Double Sided Hedge...
Echo pb 265l backpack blower bogs down at full throtle
Hi ryan...
You still have problems in the carb highspeed circuit..some debris in the passages...
BE SURE TO USE COMPRESSED AIR TO BLOW OUT THE CARB.
(be sure to watch the inlet valve seat, you can loose it and not even know it) Blow the carb clean in a box or something that will contain any part that may be expelled during cleaning.
Please take time to rate me
Bud
Mar 31, 2013 | Echo Garden
Echo gas leaf blower bog down
Sep 21, 2009 | Echo Garden
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
Jun 03, 2009 | Echo Inc. 44 CC, Carb Certified Backpack...
Echo Blower Nozzle Es 2400 Pb 200 201 2100 21001420561 Logo
112 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
