F45 error code - Washing Machines
After heating up oven displays f-45 error code then shuts down
Bosch error F45
Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
  1. Check P24 connector on the power board.
  2. Ensure door latch switches are operating properly.
  3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
  4. If F45 persists, replace power board.
press the helpful button, and check link below
Appliance Fault Codes AppliancePartsPros com
Jan 19, 2016 | Ovens
F45 error. What is the trouble?
F45 means knickers no clean
Dec 18, 2015 | Washing Machines
Error code f 43 or 45?
The situations I have encountered that refered to a F43 or F45 error code, usually ended up having to have the control panel re[placed after a series of different checks such as blocked vents and electical issue Check your warranty If the dryer is fairly new it should be covered, Also if you orginally pruchased a maintenance or service contract with the item the control panel is definately covered.
Feb 27, 2011 | Kenmore Elite Oasis ST 6806 Electric Dryer
I have an error code 45
As per Bosch,
Error Code: F45 Cause: Upper (or single) oven latch both locked and unlocked; Defective or jammed upper oven door or latch switches. Corrective Action: 1. Check P4 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are pinched to the appliance chassis. 4. If F45 persists, replace power board
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 19, 2010 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
Crashed error 03-FFFF-OOOO
if that error occurs while attempting the recovery, typically it indicates a read write error on the hard drive. replace the hard drive and see if the recovery finishes.
(although i have only seen this problem with failing hard drives)
Nov 03, 2009 | Sony Toshiba Qosmio F45-AV411 Notebook
Kenmore oasis electric dryer beeps and displays code F45
We had this error on our machine for about a year before we finally got sick and tired of it. Our dryer was purchased in 2006.
Here is the solution: the code means there is an error on the thermistor. Our thermistor was loose, as were other electrical wires. My husband tightened up all the connections and the thermistor, and we have never had this error again.
However, we will never buy these machines again either, because we have had numerous other errors on the washer and dryer.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Konica copier 3035
F45 Lens or mirror drive problem
Aug 09, 2008 | Office Equipment & Supplies
Tech support
F45-20 Color registration correction
results in abnormality.
Printer control board (PRCB)
Color registration sensor /F (PS8)
Color registration sensor /R (PS9)
May 16, 2008 | Office Equipment & Supplies
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
