Question about Memorex MT1194 19" TV
Can not get codes to turn off tv
Help us a way to unlock the tv because the tv can't turn off, on, or raise volume!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Anonymous Dec 04, 2007
  • 93 Answers
Posted on Nov 02, 2007
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
How do I remove the child lock on my toshiba 42wp56p tv without the remote?
These are the general procedure to unlock a TV
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Check this method too. If neither of them help you, check this link.
Disconnect the AC power for at least one minute to reset the clock.
Adjust the volume to the minimum using the Volume down button on the front of the unit.
Press and hold the Volume down button on the front of the unit and the 0 button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press the ENTER key on the remote control and the NEW PASSWORD menu will appear.
Enter your new password.
Jan 05, 2013 | Televison & Video
I have a Sharp LE820 TV and all of a sudden the volume level raises by itself, what can I do to solve this problem?
1st thing to do is remove the batteries from the remote and see if it still changes by itself, if it does then I'd look at main board issues
Mar 06, 2018 | Sharp AQUOS 52in. LE820 LED LCD HDTV
Front panel locked by accident- no original remote, only universal, code unknown. tv has since been turned off by unplugging, now it won't turn on. remote has also been unprogrammed because batteries were...
Three digit universal remote code for RCA are:-
000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Four digit universal remote code for RCA are:-
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Other ways to unlock RCA tvs
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
Nov 22, 2010 | RCA 27R410T 27" TV
. unable to lower or raise volume, comcast remote on olivia tv
Open the thing up and clean off all the dirt on the volume buttons with a dry rag and clean the remote sensor.  Put in fresh batteries and now give it a try.
Nov 18, 2009 | Televison & Video
Need to lock television volume on high when television is shut of
Please check in TV menu for Intelligent Volume option and turn it OFF/ ON
Let me know exact model number of TV to help you more precisely.
Feb 11, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
Concierge Hotel TV - Volume Control
If there are no chasis numbers on the outside you may want to open the cast and check for numbers there. Then you might be able to google the number and find a manual. some TV's willl enter the menu or rest by pushing two buttons at once on the set. This could change your channel selection however.
Nov 14, 2008 | Televison & Video
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Apr 26, 2008 | Sanyo DS32224 TV
Big Screen TV won't turn off
Check the voltage to the relay, usually 12v dc. Also check the relay or replace as it may be stuck after the tv warms up. The micro chip for functions could be locking up. Try spraying a little freeze spray directly on chip after tv is locked up see if this unlocks, if it does you have a bad micro chip.
Jul 20, 2007 | Philips 55P8241 55" Rear Projection...
Memorex MT1194 19" TV Logo
83 people viewed this question
Top Memorex Televison & Video Experts
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
