Question about Brother MFC-J450DW INK-JET ALL-IN-ONE COLOR PRINT COPY SCAN FAX
Init.6F error I was trying to scan when a scan xx error popped up. I contacted Brother support online chat, who suggested a factory reset. We tried it, it worked for about 10 minutes, now it is giving an Unable to Init.6F error.
Mix-it-up
  • 832 Answers
SOURCE: init unable AF
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Posted on Sep 13, 2007
Mix-it-up
  • 832 Answers
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Posted on Mar 13, 2008
SOURCE: Error 46 Unable to Init.
No need for part necessarily
SkipperOz solution pasted below
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Posted on Apr 10, 2008
  • 159 Answers
SOURCE: Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Posted on Jun 11, 2009
  • 60 Answers
SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Posted on Feb 03, 2010
"Machine Error 81" message when I tried to set up my 1950 MC
check for any papaer jam or any dust material blocking the rollers of the printer to move.OFF the printer.and blow air through the blower in whole internal area off the printer.then ON and check.
thanks.
Oct 29, 2008 | Brother MFC 1950MC Printer
Brother MFC790cw shows on LCD "unable to change
Here's the online (english) version of your Brother "Multi-Function Center" Users Manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_790CW_990CW_EN_1600.PDF
The closest thing to your error message I can find is
"Unable to Clean XX" on page 156, in which case, your All-in-1 has either a (1) mechanical problem, or (2) a staple/paper clip or torn bit of paper is stuck in the machine.
Use a flashlight to look really closely for little foreign matter that
might be jamming your device - office staples can be insidious.
Mar 14, 2011 | Brother MFC790cw All-In-One InkJet Printer
I have an Oki ES3640 Pro, the problem is that there's an error message on the front display saying "Replace waste toner box, waste toner full" but it isn't full, I put a new one in last week!...
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Jan 14, 2011 | OKI ES3640ex Color Copier
My chat doesn't work?
If you're chatting app doesn't allow you to chat, then what is its use? You should use an app that will easily allow you to chat with the people you want.
I can suggest you use kik online. This is a newly arrived online messaging app that will allow you to chat easily and for free from around the world.
You can connect with the person available in your contact or out of your contact.
Use it once, I hope you will like it!!!
Jul 01, 2010 | Facebook Social Network
Hi I have a Sont Cyber-Shoot DSC-T10 camera but it keeps giving me a E:62:10 error message please tell me how to get rid of it. ps there dorsn't seem to be a fault with the camera apart from the error...
A letter and number error code of E:61:xx , E:62:xx , or E:91:xx is an indication a malfunction has occurred in the camera. To try resolving any of these error codes, power reset the camera back to the original factory specifications.
I'll forward a link to a page where you can view the information about power resetting the Camera.
Please click on the link to open the page to view the troubleshooting steps.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C265373
Thank You!
Apr 09, 2010 | Sony Cyber-shot DSC-T10 Digital Camera
When i on my sony cybershot dsc-w35 a"E:91:01" msg will display in screen,and flash is not working
Thank You!
Apr 06, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
161 fatal error C7300
Try this - WARNING - will reset everything to factory defaults
The machine must be put back into "Shipping Mode" in order for the consumable counters to reset.
In order to place the printer back in "Shipping Mode" do the following:
0.27c?openelement&fieldelemformat=gif
1. For the C72/74/92/94 models, hold the (1) and (5) keys down, for the C73/75/93/95 hold (0), (1), (6), and (7), while turning the printer power on. (Hold until "MAINTENANCE MODE" is displayed)
2. Press (0) five times until "ENGINE DIAG MODE XX.XX" is displayed.
3. Press the (2) and (4) keys simutaneously, "ENGINE DIAG LEVEL 3" should now be displayed.
4. Press the (5) key once, "LOCAL PARAMETER SET" should now appear on the display.
5. Press the (6) key three times until "FACTORY WORKING MODE" is displayed.
6. Once "FACTORY WORKING MODE" is displayed, press (3) once so "Shipping Mode" (Fuse Cut Enabled) is displayed in the bottom line.
7. Next press and hold (3) & (7) together, until "Shipping Mode" stops flashing.
8. Power the printer off and back on, now the printer will reset the consumable counters. ecblank.gif ecblank.gif ecblank.gif
Aug 30, 2008 | OKI C5300n Led Printer
Brother MFC-5840CN unable to scan
From Brother Customer Service email:
You can try the following reset - it will most of the settings back to the default options.
Unplug power cord to the machine.
Press and hold down Menu.
Plug power cord back in.
Let go if menu when fax/scan/copy flash.
You may see either "maintenance" or "machine error xx" on the screen.
Type stop/exit, 9, 1.
The machine should show "param init" or similar to show that the reset is being done.
It will then go back to or machine error.
Type stop/exit, 9, 9.
This should take the machine out of maintenance mode and back to normal.
If the error is still present the machine will require an engineer to resolve the issue.
Jul 08, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother 5460cn won't scan to email,file,ocr,image
Brother Scanner error message.
After much time with Brother Tech support. The solution finally turned out to be as simple as downloading this file to reset the drivers.
http://support.visioneer.com/utilities/twain_reset.exe
Oct 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-J450DW INK-JET ALL-IN-ONE COLOR PRINT COPY SCAN FAX Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
