My problems I think are partly due to my own fault. The ( C ) Driver had reached 99% full and because was worried it would result at the computer breaking down-I followed the on screen advice and started to uninstall certain programmes And it resulted to my for some reason finding my way to the Colour section which displays the settings for the screen and now my screen is multi-coloured and shrunk to approx (6)inches. Are you able to advice. At present I am going through the process of up-grading the Drivers are also able to tell me how many hours it approx takes to place in the Drivers? Margo
  • 13,433 Answers
How long would it take to fix the problem? 20 to 60 minutes:
Lets solve the problem over a remote support connection - I will be able to see the screen and sort out the problem. Click on this link below:
http://www.fastsupport.com/743114116
above link will start the session, if the session doesn't start within a minute or two, use the manually download software link at the bottom and follow instructions.
Posted on Jun 18, 2009
Error code f 02
I think it's a slow drain fault. But would need full model number to say for sure. Still it wouldn't hurt to check the drain pump for crud. Here are some vids that might help. Don't worry too much about brand specifics. Many brands share identical and similar parts.
http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Kenmore Elite 45986 Front Load Washer
My 2007 Dodge cummins 6.7 is telling me to perform service and the catalyst is full. How do I fix this problem myself?
Intervention Regeneration Strategy - EVIC
Message Process Flow (Catalyst Full Message)
(6.7L Diesel Engines Only)
Your new Cummins 6.7L diesel meets all EPA Heavy
Duty Diesel Engine Emissions Standards, resulting in the
lowest emitting diesel engine ever produced.
To achieve these emission standards your vehicle is
equipped with state of the art engine and exhaust system.
The engine and exhaust aftertreatment system work
together to achieve the EPA Heavy Duty Diesel Engine
Emissions Standards. These systems are seamlessly integrated
into your vehicle and managed by the Cummins
6.7L engine Powertrain Control Module (PCM). The PCM
manages engine combustion to allow the exhaust system's
catalyst to trap and burn Particulate Matter (PM)
pollutants, with no input or interaction on your part.
Additionally, the overhead console in your vehicle has
the ability to alert you to additional maintenance required
on your truck or engine. Refer to the following
messages that may be displayed on your Electronic
Vehicle Information Center (EVIC):
WARNING!
A hot exhaust system can start a fire if you park over
materials that can burn. Such materials might be
grass or leaves coming into contact with your exhaust
system. Do not park or operate your vehicle in areas
where your exhaust system can contact anything that
can burn.
Perform Service
The 6.7L Cummins engine utilizes a Closed Crankcase
Ventilation (CCV) system, EGR Valve and a EGR Cooler.
This system filters and recycles gasses produced in the
crankcase during the normal combustion process. Perform
Service will be displayed on the overhead console of
your vehicle if the CCV filter, EGR Valve and EGR Cooler
is due for required maintenance. The CCV filter is located
on the top of the engine valve cover. For additional
information, see your local authorized dealer.
Catalyst Full See Owner Manual
Catalyst Full See Owner Manual will be displayed on the
overhead console of your vehicle if the exhaust particulate
filter reaches 80% of its maximum storage capacity.
Under conditions of exclusive short duration and low
speed driving cycles, your Cummins engine and exhaust
aftertreatment system may never reach the conditions
required to remove the trapped PM, if this occurs Catalyst
overhead console in your vehicle. If this message is
displayed you will hear one chime to assist in alerting
you of this condition.
Catalyst Stat::::::::::80%
Catalyst Stat::::::::::80% will replace the message Catalyst
Full See Owner Manual after it is displayed for one
minute. The engine Powertrain Control Module (PCM)
will continue to monitor the amount of particulate matter
trapped in the particulate filter. This message indicates
the percentage of the particulate filter capacity that has
been used.
By simply driving your vehicle at highway speeds for as
little as 45 minutes you can remedy the condition in the
particulate filter system and allow your Cummins engine
and exhaust Aftertreatment system to remove the
trapped PM and restore the system to normal operating
condition.
Catalyst Stat:::::::::::80%, 90%, 99%
Catalyst Stat:::::::::::80%, 90%, 99% If you are unable to
drive your vehicle under these conditions for an extended
period of time after the initial warning notification,
the Engine PCM will continue to monitor the
particulate filter and will display the progression of
particulate filter usage (80, 90, 99%) on the EVIC message
center.
CATALYST FULL SERVICE REQD
If the particulate filter reaches 99% of it's capacity the
overhead console in your vehicle will chime twice and
display the message CATALYST FULL SERVICE REQD.
At this point the engine PCM will register a fault code,
the instrument panel will display a MIL light and the
engine PCM will derate the truck reducing its horsepower
and torque output.
The PCM derates the engine in order to limit the likelihood
of permanent damage to the aftertreatment system.
If this condition is not corrected and a dealer service is
not performed, extensive exhaust aftertreatment damage
can occur. In order to correct this condition it will be
necessary to have the truck serviced by your local
authorized dealer.
Feb 14, 2011 | 2007 Dodge Ram Truck
My swimp3 is not being recognized by my computer. what's going on?
This is due to two reasons
1.Driver problem: You need to put the CD which you've got along with the player and you need to install the USB driver. Restart the computer. Now connect your player with the computer.
2.Player problem: If the player is not connected even after installing the driver, then that is player problem. Now reset your player and again try to connect. Even after these steps your player is not connected, contact support.
Cheers, The K.
Dec 31, 2010 | Finis Swi MP3 Player
Radiator fan wiil not come on at heat temperature and checked fuses, dont know how to chek relays
on my 99 cadi the fans dont come on till the temp reaches 220. so unless your car temp is above that i wouldnt worry. take your relays to your local parts store and they will be able to tell you how to check the relays.
Oct 28, 2010 | 1999 Cadillac DeVille
Car won't start. Error codes - p1000, p0452, p1642
The following results can be found on http://www.blujag.co.uk and would appear to indicate a fuel system problem. hope this helps
Fault Code P0452
Indicates a Generic Power-train fault
The fault is generally due to a problem in the Emission Control area
Fault Description: Evaporative Emission Control System Pressure Sensor Low Input
Fault Code P1642
Indicates a Manufacturer Specific Power-train fault
The fault is generally due to a problem in the Computer & Output Circuit area
Fault Description: Fuel Pump Monitor Circuit High Input
Jul 16, 2010 | 2003 Jaguar Xkr
The battery full charge only reach 98% & says pluged not charging!!!what this mean?
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
May 17, 2010 | Computers & Internet
19" Samsung SyncMaster washed out display
You either have a backlighting problem or the power supply is getting weak and starting to fail.
If you have another computer...connect it and see if the results are the same...also check your cables, analog and/or digital for any faults.
Good luck...i hope this helps.
Jul 18, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
I have replace my black cartridge and the ink is still reading low.
Dear Sir,
Welcome to Fixya Customer Support
I feel happy to assist you on this moment
Generally In some Printer Driver Programming lack of certain issue. For Example When Printer ink low it shows Ink is running low or ink is low but after replacing catridge also this massage continues appearing.Practically Ink is full. this is mainly due to the printer driver and software programming fault.
so no need to worry ink is full keep printing.
Once again thanking u choosing fixya Customer Support
chandrashekhar
Jul 10, 2009 | Office Equipment & Supplies
Problem with my printer
Go to www.hp.com and click on their "Software & driver downloads" link. Under "select a task and enter a product name and number", pick "download driver and software". In the "for product" box, enter "5150". In the results page, click the "HP Deskjet 5150 Color Inkjet Printer" link. Pick your operating system. After that, you'll reach the driver download page. You have a choice of "full feature" or "basic feature" drivers. Either one will work, but I prefer the "full feature" driver.
Sep 10, 2008 | HP DeskJet 5150 InkJet Printer
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
