Question about Kitchen Ranges
Control panel kenmore range
Control panel reading E0-f1 code I unplugged range and now the control panel does not go on.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
F1 - E0
EEPROM communication error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
You can order the ERC here. Search Over 2 1 Million Appliance Parts
Posted on May 01, 2014
VANMAN69
  • 23 Answers
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Posted on Jun 02, 2007
catriver
  • 878 Answers
SOURCE: F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Posted on Jun 05, 2007
rylee_smith
  • 8619 Answers
SOURCE: F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 10, 2009
  • 13 Answers
SOURCE: Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Posted on Aug 24, 2009
localwonder
  • 6784 Answers
SOURCE: Magic Chef Electric Range F1 code won't stop
Hi. this is referring to a Defective touch pad or clock (ERC). This will need to be corrected. Normally, you will need to, simply, replace the main control Board(ERC).
Follow this testing procedure to confirm the damage.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Nov 25, 2009
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Tip
    Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
    Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
    WHIRLPOOL - most models
    Range/Stove and Oven Fault Codes, Common error codes.
    F1 - Analog control board Failure
    Disconnect for one minute - if error comes back, replace control board
    F1 - Shorted control keypad
    Replace keypad
    F3 - Oven temperature sensor open
    Replace oven temperature probe
    F2 - Oven temperature sensor shorted
    F3 - Oven too hot
    F3 - Clean temperature too hot
    Replace oven probe
    F5 - Door latch switch fault
    Test and replace the door switch.
    Whirlpool with 4 Digit Failure Code:
    F1 - E1 - Electronic control (flip flop)
    Replace control board
    F2 - E0 - Shorted control keypad
    Replace keypad
    F3 - E0 - Oven temperature probe open
    Replace temperature probe
    F3 - E1 - Oven temperature probe shorted
    F3 - E2 - Oven temp too high
    F3 - E3 - Clean temp too hot
    Replace temp. probe
    F5 - E0 - Check door latch
    F5 - E1 - Check door latch
    Replace switch if defective
    WHIRLPOOL Polara models 5 digit codes:
    F1 F0 - EEPROM communication error
    Replace ERC
    F1 E1 - EEPROM checksum error
    Replace ERC
    F1 E2:7 - UL A/D errors
    Replace ERC
    F1 E4:2 - Model ID error
    Reinsert keytail.
    F1 E6:0 - Latch signal mismatch error
    Replace ERC
    F2 E0:4 - Shorted key error
    Replace keypad assembly
    F2 E1:3 Keytail unplugged
    reinsert the keytail
    F3 E0:5 Top oven sensor open
    Test and replace top probe.
    F3 E1:6 Top oven shorted
    Test and replace temp probe
    F3 E2:9 Bake range over temperature
    F3 E3:8 Clean range over temperature
    Test and replace temp probe.
    F3 E4:10 Bottom oven sensor open
    F3 E:15 Bottom oven sensor shorted
    F5 E0:14 Door switch errot
    Test and eventually replace door lock switch
    F5 E1:16 Door latch not operating
    Test and eventually replace door latch
    F8 E0:17 Refrigeration error
    Test the cooling module.
    PF Power failure - Does not indicate a fault.
    PF occurs when power is disconnected.
    WHIRLPOOL
    Models SF3, 30'' and 24"
    F2 - Oven temperature above specifications
    Check 8-pin connector from temp. probe to Electronic Oven Control
    F3 - Open oven temperature probe failure
    Check wiring, replace oven probe if necessary
    F4 - Shorted oven temperature sensor failure
    Check wiring harness, replace oven temperature probe if necessary
    F5 - Push button stuck or faulty
    Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
    F6 - Electronic control logic error (timing)
    Replace Electronic Range Control (ERC)
    F7 - Electronic control logic error (lock motor)
    Replace ERC.
    F8 - Electronic control logic error
    Replace ERC.
    on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
    I have a kenmore ultra bake, model #665 75022101 and the oven doesnt work the code E0-F3 comes up. i have the manual and have tried what they said to do but it doesnt work. i have bought a new sensor
    The error code message F3 E0 indicates an open oven sensor circuit. This is the component that regulates the oven temperature.
    First disconnect electrical power to the range. Pull the range out & remove the rear panel to the control area. Unplug the 2 violet wires on P3 5-6. You will need to have a meter for testing, set the meter to read ohms (resistance). Place the leads from the multimeter across the 2 violet wires, the meter should read 1080ohms if the sensor is good. If you do not get the correct reading you will need to replace the oven temp sensor.
    The oven temp sensor is mounted to the inside of the oven cavity. You will need to remove the lower section of the rear panel to access the sensor connector. Unplug the sensor & slide it back into the oven cavity to remove & replace.
    Taken from...
    http://www.managemylife.com/mmh/questions/120802-kenmore-range-displaying-e0-f3-error-code
    Jan 12, 2012 | Ovens
    My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
    Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
    KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
    F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
    KENMORE - 911 Series (General Electric/Roper)
    F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
    KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
    F1-E0 EPROM Error - Electronic Range Control (ERC).
    F1-E1 EPROM Error - Electronic Range Control (ERC).
    F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
    F1-E3 Fuel Type Fail
    Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
    “9” for gas-If code changes again-replace Electronic Range Control (ERC).
    KENMORE - 790 Series Electronic Oven Control (Frigidaire)
    F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
    Runaway Temp = Replace Electronic Oven Control (EOC).
    Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
    Thanks
    May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
    Kitchen aid wall oven Model YKEBS2780B1 SHOWS
    Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3
    Thanks
    May 26, 2010 | Ovens
    66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
    Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
    Thanks
    Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
    THE OVEN IS READING EO F1 WHEN I TURN IT ON??
    F1-E0 - EEPROM Communication Error - Disconnect power for at least 30 seconds and then reconnect.
    Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jul 17, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
    My kenmore oven is beeping and will not stop. the display shows F-1.
    Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
    F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
    Dec 16, 2008 | Ovens
    My kenmore electronic stove is having a beep with code F1 on the
    Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Kenmore electric Range model 635040L0
    F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
    Select the 'cancel' function and wait 60 seconds.
    If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
    Sep 24, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
    Kitchen Ranges Logo
    37 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
