hello, if yonth place youur talking math then it means to make answer to thousandth place
ex 1.234
2 is in 10s place
3 is in 100s place and
4 is in thousandth place
so it is 1.234 to the thousanth
Step 1 - identify the thousandths column - going to the right of the decimal point, we have the tenths column, the hundredths column, and the thousandths column
Step 2 - check the number immediately to the right of this column
Step 3 - if this number is 5 or more, add 1 to the thousandths column - if this number is 4 or less, don't add 1 to the thousandths column (leave it alone)
Step 4 - erase all the numbers to the right of the thousandths column.
In this case, the number in the thousandths column is 4. The number immediately to the right of it is a 0. Since the 0 is 4 or less, we don't add 1 to the thousandths column. Now we erase all numbers to the right of the thousandths column. I get 22.524.
Do you mean round off to the nearest thousandths? The thousandths place is the third place to the right of the decimal point. An example would be 0.001. In this case you have a 1 in the thousandths places which would be stated as one thousandth. To round to the nearest thousandths place you would look at the number in the ten-thousandths place and use that to determine what the number in the thousandths place should be. For example, if you have a number such as 0.1234 your answer, rounded to the nearest thousandth would be 0.123 because 4 is less than 5 and therefore you would round down. If you have a number such as 0.1235 your answer would be 0.124 because you always round up if the number in the next decimal place is 5 or higher.
