Question about Bush BSCF145 Chest Freezer
How do you defrost a bush 145l chest freezer - Bush BSCF145 Chest Freezer
I have a bush chest freezer CF-143GB. Recently the compressor runs continually. It can be stopped by turning the thermostat right down. A little while later and having reset the temp control it restar
Sounds like it has an auto shutoff if issues arise
Try clearing all vents - inside (make sure vents not covered) and out (vacuum - the coil areas)
Sep 11, 2014 | Freezers
My chest freezer bush cf143gb works ok but the green light does not show it is
Good day James.
There must be a loose cable for the green light to come on. Your thermostat might need replacement especially if doesn't go on defost which happens automatically.
Feb 12, 2014 | Bush BSCF145 Chest Freezer
Frost building up at the coil. i think the defroster does not work
Chest freezers are manual defrost. Which mean yall unplug it to defrost it.
May 12, 2011 | Woods Chest Freezer C1501W3
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
General electric 5.0 chest freezer has water coming all over the floor.
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor. A new defrost timer should be available from the local refrigeration wholesalers in your area.
May 11, 2009 | General Electric Chest Freezer FCM5SU
Kelvinator novelties chest freezer
check the defrost timer, defrost limit, and defrost heater.
Apr 21, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Bush BSCF145 Chest Freezer Logo
69 people viewed this question
Top Bush Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Bush Freezer Expert? Answer questions, earn points and help others
