Question about Kubota Garden
Bx2350 pto replace - Kubota Garden
PTO turns with mwoer shaft disengaged, blades turn when shaft is rotated by hand. Put shaft into PTO housing and the mower wont turn.
bad pto, 400 dollar to fix but a cheap option is to replace the pto switch in the dash first, is the pto switch clicking with the key in the ON position? if it is then it is the pto clutch bad
Jul 29, 2015 | Garden
I have a jd170 and as soon as I hit the pto switch the mower dies I just replaced the $40 pto switch and that's not the problem
if the blades turn freely then you are going to have to replace the pto or ignition switch,take the drive belt off,does the pto work?,if not,it is electrical,check switch then pto,then pto safety switch
Apr 21, 2015 | Garden
Pto switch will not work...it was replaced tnd it still will not work
check for voltage at pto if voltage there jump pto at the wire hub on pto if still pto dosnt come on bad new pto return it for new one and they get bad one it is a problem if good pto check voltage at pto should be 12.5 at least if not you got a bad stater 200.00 for it then install another 100.00
Aug 29, 2014 | Garden
I have a cub cadet rzt50 2006model, when I pull the PTO switch to engage the PTO nothing happens
check to see if you have voltage to pto if do bad pto replace it if not check the fuse then the switch
Aug 26, 2014 | Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Engine dies when PTO is engaged. I thinking of replacing the PTO!
It sounds like you may have a siezed bearing or something jammed in the PTO mechanism. In any case, you will have to strip the PTO to troubleshoot it. A complete PTO replacement will probably not be called for, just the defective part.
Jun 09, 2011 | Swisher ZeroTurn Mowers
I want to open the Monitor.
Get professional help. Take it to a bestbuy or something around the area. Doing it yourself may be very annoying due to all the cables that it has once opened.
It shouldn't be much of an issue.
Goodluck
Apr 25, 2011 | Samsung BX2350 23" Widescreen LED Backlit...
Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
May 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Pto clutch keeps shutting off
If you have not replaced the pto switch do so. If you have check wiring from switch to the pto coil. Many times the wiring at the pto coil is rubbed by the belt until it wears the wire into. You can also try energizing the coil to the pto directly from battery (With engine off of course) If it energizes and stays energized it is probably not the coil.
May 03, 2009 | Garden
Garden Logo
12 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
