Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
How do I remove contents on my 250gb Goflex free agent
DID NOT UNPLUG MY EXTERNAL DRIVE CORRECTLY. DO I NEED TO RE-FORMAT THE EXTERNAL DRIVE AND START OVER
no don't do it. as per mi experience, I did not. just change the name of your drive and run chskdsk :/f
Feb 02, 2012 | Seagate Freeagent Goflex 500 GB USB 2.0...
What is the safe removal procedure for the Free Agent Go Flex external hard drive
Click on the icon with the green arrow in the notification area (next to the clock) a small notification about Safely Disconnect will appear listing all the connected devices - click on the entry corresponding to your GoFlex and wait for the message telling you that is safe to do it or, in some cases the icon will blink (that depends on how your pc is set up). Once that is done just take out the USB cable.
Jul 12, 2011 | Computers & Internet
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
Can i directly watch the movies in the free agent go flex with my hdtv?
i think you can not play movey direct from your hard drive to your hdtv
Feb 19, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
Just bought the GoFLex Pro 750 GB. I have two PCs, both on XP... neither can see the HD via my computer... I have done a check via computer managment and it says the HD is fine... but it is not...
Hi, Thanks for using fixya.
Remove any usb devices from your computer other than your Free agent then reboot the computer see if it is reconized and it is useable. Then plug in your other devices one at a time make sure you see the Your device is ready to use. If your Free Agent is not reconized got to Seagate.com search for your device driver. Remember when you want to pull out any usb device make sure you remove it throught windows first. Fastest way is to go in My Computer or Computer right click on the device and choose eject. After the name changes to removable device it is safe to pull our.
Hope this helps,
Terry
Feb 17, 2011 | Seagate FreeAgent GoFlex Pro 750 GB USB 30...
I have purchased a Seagate free agent Goflex 500gb I want to run it with my Mac Pro note book it dose not work
For a MAC to use an external Hard drive, the hard drive has to be formatted FAT32 file system. That is the only file system MAC sees.
Jun 24, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do i retriev my stuff of it to put on computer?
Assuming the harddrive is working, plug it in and click start and my computer( or computer if you are running vista or 7) and then in this window click the name of the harddrive. Then drag and drop?
If you used 3rd party software to back up your data you will need to install that first and run the recovery option
May 02, 2010 | Western Digital WD Passport 250GB Portable...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
21 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
