Question about Transcend T.sonic MP330 MP3 Player
Unlock the ipod
Error opening show the icon is locked
IPOD NANO 8 G is locked. How do I unlock?
Plug the iPod USB cable into the bottom of the iPod Nano.
  • Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer.
  • Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC.
  • Click on the name of your iPod Nano under the "Devices" list in the iTunes window.
  • Click on the "Sync" button to establish a connection between your iPod and the computer.
  • Click on the eject symbol next to your iPod's name after the syncing process has finished.
  • Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again.
    WARNING
    To unlock your iPod Nano, you must connect the device to the computer it has been previously synced with.
    Sep 28, 2009 | Apple iPod nano
    I am not able to unlock my iPod classic. Tried different way to unlock but not successful. I tried toggle on and off then reset the iPod. Also I restored the iPod but still not been able to use click...
    Usually if your lock Icon is visible on any ipod, that indicates the Hold "button" is in the locked position. If the hold button isn't in the locked position, I'd try sliding it to the locked position and then back over to the unlocked position as the button sometimes comes free of the bracket that actuallys slides the switch.
    Jul 30, 2009 | Apple iPod MA446LL/A MP3 Player
    I have ipod A1137 2GB. I've been using it in the States, but now I'm in Seoul, Korea. When I tried to recharge it, there showed 4 numbers safety deposit box lock. Even though it was fully recharged, I...
    YOUR ENTERED A LOCK CODE IF YOU CAN NOT REMEMBER IT DO THIS..OK first plug/connect ipod to computer.go to my computer click on ipod icon and format.After format download itunes and install it to the harddrive.Reboot.open itunes and it will see ipod and load the drivers.More questions or confused,just contact me.Have a great day and if this helped please vote thanks.RICHARDM69
    Jan 19, 2009 | Apple iPod nano
    My Ipod is lock and i cannot unlock it.
    When connect ipod to computer, go to my computer. Click on ipod:-
    -click on tools, go to folder options
    -go to view tab
    -check show hidden files
    -a ghost like folder will apear: ipod control
    -click on it and go to device
    -there will be a locked file
    -click and delete it
    Your ipod is unlocked!!!!!!!!!!!!
    JOHN
    If you don't understand, go to this website on you tube!
    http://www.youtube.com/watch?v=Au6H_u-q434
    Nov 27, 2008 | Apple iPod nano
    My ipods locked and i 4 got the code and cant get on to itunes !!!!
    Thanks to everymac.com i found your answer, i was interested in what would happen.
    Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize.
    Oct 21, 2008 | Apple iPod nano
    Help
    You need to attach it to your computer to unlock it. Your local computer store might sell Ipod USB cables.
    Connect the iPod and go to 'my computer';
    -open the iPod by right clicking on the iPod icon;
    -on the toolbar menu click on 'Tools'
    -select folder options>view>& check the box that says "show hidden files & folders"
    -then click 'ok'
    You will see a ghost folder called 'iPod control'. Open this folder to access the other folders & files contained within it.
    Delete the file called "Itunes_lock"
    Jun 25, 2008 | Apple iPod MA446LL/A MP3 Player
    I got my ipod locked its showing lock sign .
    Is it a press and hold button to unlock or a slide switch, if it's a press and hold you may need to just press and hold the play button til the lock icon disappears.
    Jan 19, 2008 | Apple iPod 4th Generation MP3 Player
    Ipod always on hold
    plug it into your comp and iTunes will unlock it for you
    This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
    Dec 28, 2007 | Apple iPod nano
    Transcend T.sonic MP330 MP3 Player Logo
    13 people viewed this question
    Top Transcend Audio Players & Recorders Experts
    Gyula Lacz
    k24674
    IT Solution
    IT Solution
    Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
