Viera panasonic tbm2ax14201 wont turn on
Red ligh blinking. wont turn on
Kimi
  • 277 Answers
SOURCE: Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Posted on Oct 21, 2005
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
Raditronic
  • 196 Answers
SOURCE: panasonic viera wont come on
The problem is not the power supply, is with the tunner board voltage. change the P.A board fix the problem.
Posted on Apr 22, 2010
  • 418 Answers
SOURCE: panasonic 42
Loss of power from power supply. Usually bad power supply.
Posted on May 02, 2010
  • 8457 Answers
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Posted on Jun 22, 2010
Red ligh blink
The red light blinking usually means the tv cannot find a video source, check your cables and make sure if your using HMDI or Component the tv source is set at that video source.
Jul 01, 2011 | Televison & Video
I went to turn on my tv tonight and it started to come on - then did not.. a blinking red ligh is where the green light usually is - I tried to unplug it and re plug it in.. no help
When you turn the TV on, does it attempt to come on and then off? Does the light go green when you attempt to power up and then goes red?
Jan 31, 2011 | Philips 37PF9631D 37 in. LCD HDTV
What does the blinking red ligh t mean below picture of battery
This usually means that your battery is not charging. Take the battery out and turn the computer on, plugged in only. Shut the computer down and then replace the battery. If the led light is still blinking red, it is time for a new battery. You can find a replacement battery on eBay for a reasonable price.
Sep 16, 2010 | Computers & Internet
The monitor ligh just blinks on red then green, but no image
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Sceptre monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 28, 2010 | Sceptre 17" LCD Monitor
Wont kick wont start i see the red ligh lights blinks 2 times then 4 times what shall i do thanks
4 Flashes indicates an over heat. Either the room air blower could not push enough air over the heat exchanger due to a blocked filter or closed registers. You will need to replace one or more of the sensors to get the unit back up running. Test each sensor with an Ohm meter to find out which one blew. There may be a reset button on it if you are lucky.
Dec 30, 2009 | Goodman GMS90703BXA Heater
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Replaced lamp on sony 60'' sxrd tv and now get 3 red blinking ligh
I am having the same issue, just replaced bulb not it blinks 3 times. Any ideas?
Mar 26, 2009 | Sony Televison & Video
MY TV
IF it's blinking it's probably an error code. If you have the manual see if it says what it means. If not, post the blink sequence here, maybe someone knows what it means.
Dec 05, 2007 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
