Question about Garden
Hedge trimmer cuts out when revved - Garden
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
boscia
  • 163 Answers
SOURCE: Electric Hedge trimmer will not cut
more than likely it damaged the inner gears or drive pins that make the blades reciprocate and need replaced. if you would like instructions to repair it yourself i will send you them or you can take it to a service center.
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
dmiesner
SOURCE: ECHO HC-1500 hedge trimmer wont stay running cuts off
Replace the fuel cap.
Posted on May 29, 2010
SOURCE: Accidently cut cable on GT450 hedge trimmer. I
Me too - I rewired the cable into the junction inside the unit and after reassembly it stopped working. I've narrowed it down to the internal switch(es). There's a black and a red alongside one another. When pressed together - no power. When only the red is pressed - power. But the orange, external handle press engages them both at the same time and I can't see how to avoid this after it's back together
Thanks, Matt
Posted on Oct 03, 2010
Why is my Husqvarna x series hedge trimmer 325HE4 NOT REVVING UP TO FULL POWER.?
There are 2 adjustment screws on the carburetor. Both have to be adjusted to get full power.
Aug 21, 2014 | Garden
Blades will not operate when engine is running on my HS 81-R hedge trimmer
check the gear box where the motor meets the drive
Mar 29, 2012 | Garden
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
Jun 15, 2011 | Homelite Garden
Cutting blade for 8124-04 Type 5
Do not try and replace the blade.
They are not ment to be replaced let alone even resharped
If it can not cut any more time to buy a new model
Jul 21, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Hedge trimmer not delivering enough power
Check the condition of the 'spark arrestor' screen on the outlet of the muffler. clean with a wire brush and re-install
Oct 18, 2009 | Garden
Trimer buing Question
Double position trimmers For extended reach while on the ground, a double position trimmer avoids you having to climb up high by allowing you to adjust the handle into a right angle to the blades for a level cut across the top of the hedge. Clippings collector As you trim your hedge, collect those stray cuttings in a clippings collector for a neater finish. Automatic cut out An important safety feature, this automatically switches off the hedge trimmer once the trigger is released. Hand guard For reassuring safety, a hand guard will protect you from the moving blades and from falling cuttings as you work.
Aug 27, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
Trimmer safety problem
# Keep all people and animals away from the area you're working in # Hold the hedge trimmer correctly using both hands # Make sure the hedge trimmer's switched off and idle before attempting to remove any jammed cuttings # Wear protective clothing including heavy-duty footwear and safety goggles to protect your eyes from flying cuttings # Electric hedge trimmers: Don't use in wet weather. Keep the cable well away from where you are cutting and check that the socket outlet has working RCD protection # Read the manufacturer's instructions before use
Aug 27, 2008 | Walter Drake Garden Groom
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
